goodie wrote:
Just wondering why you needed to prime the oil pump ,have you just rebuilt the engine ?
Oil pump on a Mini is lots higher above the oil than on most cars.
If motor has been standing for a month or 3 I don't bother. But if it's been sitting in the corner for a year or 2, I prime the pump.
I fill with an oil can through the banjo bolt hole, turn engine backwards a couple of turns with a spanner, fill again, then put the bolt back in slightly loose and the oil sender out.
THEN I crank it with the starter. Tighten the banjo when oil runs out, replace the sender when oil gets to the hole and it runs out there too.
Why do I fill at the banjo bolt hole?
It leads down to the oil pump (as does the relief valve hole) but it's much higher up, so you can build a head of oil above the pump without it running out. No need to pull the relief valve out (in fact it keeps this oil in there, it can't run away).
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
