It is currently Sun Jul 27, 2025 9:08 am
 Post subject: What head is this?
PostPosted: Mon Mar 26, 2012 12:13 pm
Hi all stupid me cant find any numbers to work out what this head is.
It reads:
12A 1456
heres a pic
Cheers, Steve
PostPosted: Mon Mar 26, 2012 12:22 pm
Stock 850/998 head isn't it?
Edit: yep...
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
PostPosted: Mon Mar 26, 2012 12:42 pm
nothing special then :? has had all the ports valves cleaned up and enlarged. Was sitting on a +40 thou 1098. It should be alright shoudnt it? performance wise
Thanks smac :D
PostPosted: Mon Mar 26, 2012 12:53 pm
Depends... With slightly bigger inlet valves and some porting it may well be just as good as a 12G202 head, as per stock 1098 :wink:
PostPosted: Mon Mar 26, 2012 12:55 pm
Ohh.. :( Wish my 295 was still good..
PostPosted: Mon Mar 26, 2012 1:11 pm
You can port them out & fit big valves just like you can with a 202, but there's more metal to remove.
Way back when they were all we had, I used to start by sticking a 1-1/16" drill down the inlet ports. :P
PostPosted: Mon Mar 26, 2012 1:48 pm
Im keen to do this :wink: How far down do you drill? Is it a complex task or would i be able to attempt it with the right tools?
PostPosted: Mon Mar 26, 2012 2:42 pm
Stop before you get to the Y bit (aka a bifurcation).
Then blend the ports back in with a die grinder. Works good with 202 or 295 inlet valves.
Make sure you drill it straight in a big bench drill or a milling machine- there is only about 1-1/8" of space between the edges of the 2 pushrod holes.
If you eff it up don't worry, the world is full or 12A1456 heads. :mrgreen:
PostPosted: Tue Mar 27, 2012 5:41 am
What does an unmolested 202 head sell for in aus these days?
PostPosted: Tue Mar 27, 2012 6:34 am
~$50 for a 202 needing reco, $100 up for a good one complete, with good valves still.
295s bring a lot more, but they tend to be cracked more often than 202s from my observations.
PostPosted: Tue Mar 27, 2012 7:36 am
Ya I have a rusty old 295 sitting here but I'm not sure it's even worth getting it cleaned up and tested.....pretty pitted.
Users browsing this forum: Bing [Bot] and 73 guests
