It is currently Mon Aug 04, 2025 8:36 pm
 Post subject: Dyno results
PostPosted: Fri Mar 30, 2012 7:20 pm
Hey guys, i recently just had my 1100 dyno tuned the other day, it got 33.6hp i was just wondering if this is what i should be expecting from it?
It was orignially a 998cc but this is what is fitted:
Bored to 1134cc
1100 crank
1100 head (shaved) slighty worked
double valve springs
stage 2 cam
LCB extractors
pulsar distributor
32mm dellorto
PostPosted: Fri Mar 30, 2012 8:36 pm
33.6HP sounds a bit low to me, Spiro the Moke (1152cc, RE13 cam, 295 head, and a 40 Dellorto) made 47HP at the ausmini dyno day a few years ago, and it was tired.
However, it was on a Dyno Dynamics dyno; chassis dynos do vary a lot, they can't really be compared with each other reliably.
PostPosted: Fri Mar 30, 2012 8:45 pm
I agree, my 1100 van had 44hp when new. 202 worked head, 266 cam, extractors and 1 1/2" SU.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Mar 31, 2012 7:59 am
Yeah interesting, thanks for that guys i think i may start saving for a 1275
PostPosted: Sat Mar 31, 2012 10:11 am
nup, getting your existing setup to perform properly will be a lot cheaper, the should be another 10-12 bhp lurking in there somewhere
PostPosted: Sat Mar 31, 2012 10:48 am
simon k wrote:
nup, getting your existing setup to perform properly will be a lot cheaper, there should be another 10-12 bhp lurking in there somewhere
Unless that Mainline dyno is just reading low (relative to the Dyno Dynamics type ausmini runs have used before). :wink:
There are so many variables- just changing sticky race tyres for hard old road ones gives you HP, we found. Same with tyre pressures.
PostPosted: Sun Apr 01, 2012 9:17 pm
Just had mine dyno'd, first tune since the new rebuild.
43.2HP
1098 +40
standard reconditioned head (head and deck shaved)
45 webber (choked down to 40)
3 into 1 extractors and rc40 exhaust
standard distributor and points
mild cam grind
I also noticed that mine was run in 3rd gear and reached 43.2 @ 100K's
Dalmeny
PostPosted: Sun Apr 01, 2012 10:04 pm
Yea that is a bit low.
Check your tire pressures and it also looks like it was taken in 4th gear - most runs are done in 3rd for a mini so that might make some difference?
PostPosted: Sun Apr 01, 2012 11:26 pm
When my van was an 1100 , it made 48 bhP ATW on that same (John collins) Dyno. Unknown cam, 295 head lcb, 40 mm web.
Then went to a 1360 with standard head 266 cam 45 mm weber- 60atw
Now 1360 Same cam 7 port head 2x 40 mm del - 90atw.
John is very good at what he does.
Now with 2 extra ports!
PostPosted: Mon Apr 02, 2012 9:24 am
Hi Jaz
I think before you go to the big step of changing to a 1275, I would recommend the head be modified first by a reputable head modifying person and then Dyno again
It is amazing how much difference a good head can influence power output in a mini
Next option would be the camshaft as you are unsure on its specs?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Apr 06, 2012 4:11 pm
Thanks for the advice guys :)
Users browsing this forum: Bing [Bot] and 95 guests
