hi guys
My SPI mini seems to give a small puff of smoke on start up/ crank over, this is then followed by a fair bit of moisture spitting.. Now i can assure the car doesn't use ANY water..
So... is it the exhaust design? After it has been run there is no issues with exhaust moisture at all... I think the swept design is caputuring moisture?!?! It has done this since i got it on the road recently.... Here is a picture:
Also when it has sat after a run allowing the heat to soak in the idle seems to sit at 1500rpm, as a guess and i hope someone will confirm, it probably needs alot of the inlet and exhaust gaskets replace as the is probably a leak that shows up on heat expansion?
Thanks
