It is currently Tue Jul 22, 2025 12:01 am
 Post subject: Fuel sender rubber seal
PostPosted: Mon Apr 02, 2012 6:28 pm
should any sealant be used on the rubber seal? I jammed a new one in and it leaks :x
PostPosted: Mon Apr 02, 2012 6:52 pm
Mods rock!
I've only ever fitted them dry. I don't think there was any sealant used from the factory. What I have noticed though is that they are a prime place for rust and that would make it leak.
PostPosted: Mon Apr 02, 2012 7:20 pm
I found a smear of rubber grease helps fitment, and it won't harm the rubber.
PostPosted: Mon Apr 02, 2012 9:10 pm
I had this problem a few weeks ago and luckily the tank was not full :shock:
I had fitted a new rubber and new sender and it was leaking
I removed both and made sure the surface in the tank was clean and I also knocked the tabs, that the sealing ring press against, up so the we're more vertical so the sealing ring was able to clamp down tight onto the sender. I think this was the problem because when I tried to clamp tighten the sealing ring it "popped" out from one of the tabs and I suddenly had a bigger leak than original :? :shock :
So far all good now :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
Users browsing this forum: Bing [Bot] and 94 guests
