It is currently Sun Aug 03, 2025 2:14 pm
 Post subject: Tuning Questions
PostPosted: Thu Apr 05, 2012 4:22 pm
1. What timing mark or degrees should you run a standard 1275 with low compression pistons on?
Have seen 3 and 5 degrees
2. What temperature should the car run at normal driving and use?
3. Have a metallic tapping noise that comes on sometimes after revving and goes before idle, hard to tell what area of the engine bay it is coming from.
Thanks
PostPosted: Thu Apr 05, 2012 6:07 pm
The rattle is the radiator shroud.
 Post subject: Re: Tuning Questions
PostPosted: Thu Apr 05, 2012 6:52 pm
Thanks
1. somewhere there - realistically those figures were correct with a brand new distributor, fuel system and 1960's fuel - todays figures can be a lot different, but that's your starting point.
2. ideally 82 degrees C - where the thermostat runs. Shouldn't spend much time over 90 though
Users browsing this forum: No registered users and 124 guests
