It is currently Mon Aug 04, 2025 10:24 am
PostPosted: Thu Apr 05, 2012 10:19 pm
Been searching but cant find if anyone has any pics or a writeup of doing this conversion.
Can anyone share a link?
I have my parts so will be giving it a go soon.
Thanks
PostPosted: Thu Apr 05, 2012 11:25 pm
don't think so, but if you take plenty of pictures, you can have the honours ;)
If you've bought a complete kit, it's an "remove old stuff" and "install new stuff" type deal. I assume the kit isn't assembled as well, so you'll need to read the manual to find out how to shim the balljoints properly, and read the how-to on setting the preload on the wheel bearings.
The worst part is probably getting the old CV joints off the driveshafts so you can install the new ones. Put the driveshaft vertically in your vice with the CV hanging down, and hit it really really hard with a big hammer - make sure your feet are out of the way.
Screw (and tighten) the brake lines into the calipers before you bolt the calipers onto the uprights, that way you can spin them around as you do it up, it's about impossible otherwise.
Another trick for young players is to make sure the caliper bleed nipples are at the top, not at the bottom - if the bleeders are at the bottom you'll have a big bubble in the top of the caliper you can never get rid of
PostPosted: Fri Apr 06, 2012 7:59 am
this is what i found for the minisport type disc conversions - plus i coughed up the extra $150 to have it arrive assembled, makes it a breeze.
however..
..definitely do this, it's how i realised they'd sent me two left hand side calipers. :lol:
PostPosted: Fri Apr 06, 2012 9:27 am
I did this conversion a few months ago. Everything went together well. As simon k said, make sure you shim up the ball joints as per the workshop manual.
I found the metal clips to hold on the CV boot went close to hitting the inside of the hubs. A gentle tap with a small hammer to sit them flat made sure they cleared the hub.
Also make sure you change the back brake cylinders over to 5/8 inch. Check your front and back flexable hoses while you are at it for signs of perishing.
Take your time and double check everything.
PostPosted: Fri Apr 06, 2012 10:18 am
Front should be changed.
PostPosted: Fri Apr 06, 2012 10:36 am
I bought my kit from josh from miniimports and the hubs are all assembled so that will save me a fair bit of time. Ill take a lot of pics and see how I go.
PostPosted: Fri Apr 06, 2012 10:38 am
sounds good - so in that case, you'll just need to unbolt the calipers to do the hoses
did it come with driveshafts, or do you need to use your own?
Users browsing this forum: Steam and 92 guests
