It is said if you keep your hand on the gearlever this can wear the selector forks, IMO this applies more to these rodchange boxes than to the magic wand and remote boxes. Both those have hard stops to limit selector shaft travel, but it's still a good idea.
Actually Doc, the Wand and Remote Shift Boxes do have (and must have) over-shoot to work (look in the black book, pp f-6, 'Selector Shafts').
I've seen selector forks wear just as bad in all types of gearboxes. It is a little worse in a Moke and any Wand Gearbox as the gearstick always leans back, putting constant pressure on the 2nd and 4th gear sides of them. It's not so bad in a mini (as the gearstick is almost up-right), but traveling with hand on stick will kill any of them.
