It is currently Wed Aug 20, 2025 7:11 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 14, 2012 1:19 pm
Ok fuel pump not issue, fuel coming out good from hose.
PostPosted: Sat Apr 14, 2012 1:38 pm
Can you get someone to turn the key while you hold each lead close to the engine in turn? I know you said you couldn't see a spark inside the lead, but you really need the end of the lead to be close to an earthing point to see it arc.
Also, was it wet/humid when the car was last running? Did you go through any puddles? Pull off the dizzy cap and give it a spray with some WD40/wipe clean with a dry cloth to ensure there's no moisture trapped in there. It could just be some condensation trapped in there. Another member had a similar problem a few weeks ago I think...
'77 Leyland Mini Van
PostPosted: Sat Apr 14, 2012 2:53 pm
Ok spark in all plugs, no moisture in dizzy cap. Charging battery now and will check to see if there fuel on plugs
 Post subject: Confusion
PostPosted: Sat Apr 14, 2012 4:22 pm
You are confusing this poor guy and he does not sound too mechanically minded. MATE DO NOT MIX PETROL WITH SPARK for god's sake. Mate try and get someone who knows what to look for to look at it for you. We do not want any disasters on our hands.
"Let us remove your "SHORTS"
PostPosted: Sat Apr 14, 2012 5:55 pm
Did you have the spark plug in the lead, then have the head of the spark plug on the block.
Simplify and add lightness
Users browsing this forum: No registered users and 240 guests
