It is currently Sat Jul 19, 2025 7:28 am
 Post subject: Internal Gear shift
PostPosted: Mon Apr 25, 2005 8:34 pm
Guys I was wondering if anyone has experience or knowledge of how to make a remote gear change internal (like you see in the English race minis)???
If not, any ideas where to find out or how to do it???
thomas
68matic: "i havent seen much head in my life "
PostPosted: Mon Apr 25, 2005 9:01 pm
Can only be done with a Rod-change as far as i know.....
I was thinking of doing it.....
(seems I'm the only one around here that thinks that Rod change is Ok !)
J
PostPosted: Mon Apr 25, 2005 9:13 pm
Can be done with any gearbox, for a lot of different reasons. :wink:
The original "remote" gear shift in a mini was a shift that bolted to the top of the tunnel and hooked up to the "magic wand" gearchange.
In Australia I have seen some Sportsedans with the Cooper S/Deluxe style remote shift above the floor. The reason for doing this is quite simple, If you lower the car too much you end up with the driveshafts running on too great an angle. So you lower the body and keep the engine where it was.
PostPosted: Mon Apr 25, 2005 9:19 pm
J
Notice how you said 'Ok' and not great :lol:
PostPosted: Mon Apr 25, 2005 9:23 pm
i need to do it as i have a 3 inch exhaust going all the way through'
no more room when that goes in...
any idea how to do it???
PostPosted: Mon Apr 25, 2005 10:32 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
use a smaller diamiter zaust ???
makka
PostPosted: Mon Apr 25, 2005 10:39 pm
He's whacking a turbo in though, may need it..How big is Grants..or James?
PostPosted: Mon Apr 25, 2005 10:54 pm
theres nothing wrong with my rod change apart from when u lift it for reverse if u do it slightly wrong the pin that holds the shifter straight pops out slightly allowing it to spin, its annoying, how do i stop it, dont say get a remote one
Potato
PostPosted: Mon Apr 25, 2005 11:21 pm
write another topic meeni.... this is not about fixing gear change linkages, its about modifying them to inside the car.
PostPosted: Tue Apr 26, 2005 6:57 am
My exhaust is 2" .....
Thinking about a 2 1/2 though .......
J
PostPosted: Tue Apr 26, 2005 9:09 am
yeah i have contemplated this too, but i have a good remote box atm so not as easy as a rod change.
my zorst is 2 1/2" ans it sits very low and does scrap a fair bit on bumpy roads.
when i build the next motor and box i think i will be going rod change and fitting it in the cab but i do not really want the bulkness in the cab but will see how it all looks...
from what i have read about it all you have to do is fit some sort of universal joint in the rods to get the adjustment of the angle right, people have used uni joints from a socket set and welded them inline.
100% Pure A Series Turbo
PostPosted: Tue Apr 26, 2005 9:31 am
Sounds almost dodgy enough for me to do it :lol: :wink:
Nah seriously, I think steering shaft unis would be better suited for this. Would look a whole lot more factory than socket set unis that's fo' sho!
Damo.
PostPosted: Tue Apr 26, 2005 10:13 am
Why not just bend the rod change mechanism to come up through the wand hole...
Straight one goes like this _____________
Bent one like this _____/
Bit like this..
PostPosted: Tue Apr 26, 2005 10:49 am
That's pretty neat 8)
PostPosted: Tue Apr 26, 2005 11:41 am
Or you could get a minimatic gear console and bolt on a matic transmission
http://www.angelfire.com/mech/ducho/painted_front.JPG
copy and paste
btw. whitestriped that looks very interesting
Inconspicuously Conspicuous
