It is currently Sat Aug 23, 2025 12:52 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 329, 330, 331, 332, 333, 334, 335 ... 568  Next
PostPosted: Mon May 14, 2012 12:29 am
michaelb wrote:
Went for a drive down MonaVale road and back :twisted:
Luv the Supercharger
Just need to sort out the fuel build up when stopped at the lights, at the moment I find a couple of blips of the throttle before I take off seems to burn off the excess fuel and prevents the engine from bogging down .
Hey Mona Vale Road...
Doing some design work down that way at the moment.. Not for RMS(RTA) though..
Alec
PostPosted: Mon May 14, 2012 7:31 am
Got motor in... Only managed to crush my hand once :oops: got to buy some cooper s wheel bearings after work today. Didn't realise they where $90 a pop :shock: drive shafts and everything else back on tuesday night. Need a new non vone toughened windscreen.
PostPosted: Mon May 14, 2012 11:10 am
Cut off the rear beaver, bit of rust in the corners, about to mate up the new boot floor.
had my new SC12 arrive today, hammina hammina.
So... I'm Seifer
PostPosted: Mon May 14, 2012 5:33 pm
Painted the gear stick boot surround because i was sick of the rusty worn look.
Had some blue left from the engine so used that.
Cheers, Rhys
1977 Leyland Mini Van - Sold
PostPosted: Wed May 16, 2012 10:11 pm
Almost got the new clutch in, just gotta bolt up all the bits that had to come off to get access and it should be right to go again.
My '78 Leyland Mini on flickr
PostPosted: Wed May 16, 2012 10:18 pm
Cheers, Rhys
Missed a spot
You're so square
Baby I don't care
PostPosted: Thu May 17, 2012 10:26 am
Sure it's not just flash glare Adam?
PostPosted: Sun May 20, 2012 7:24 pm
Moved it to the front yard.
Installed a new downpipe on the new carport.
Moved it back under cover.
Went to the other side of the house and started on the patio finishing jobs.
So basically 20 seconds of driving and no jobs...
Alec
PostPosted: Sun May 20, 2012 7:38 pm
Cut out the wheel well. Made a template to replace, decided 1.2mm is probably too thick... mainly cause its a pain to cut cleanly. Looking for alternative.
So... I'm Seifer
PostPosted: Sun May 20, 2012 9:34 pm
Thanks to another members wealth of knowledge all my electrics are all working beautifully!
Also a big thanks to the guys at Link Automotive in Melbourne for helping me out with a Brake master cylinder, which is freshly installed and an Aston flip top Fuel cap as a little treat for my mini for being so patient :)
Just gotta re plumb the brakes bleed them and take her in for a RWC!!
1971 Mini Clubman 1100
1968 Morris Mini Deluxe 998
http://www.facebook.com/geelongminiclub
"Everybody should drive a Mini, everybody should own a Mini at some point, or you are incomplete as a human being." -James May, about the classic Mini.
PostPosted: Sun May 20, 2012 10:16 pm
Picked it up from the body shop
PostPosted: Sun May 20, 2012 10:29 pm
won a motorkhana
PostPosted: Sun May 20, 2012 10:30 pm
I hooned a little but nobody saw me, so it didn't happen, haha. :shock: :roll: :shock: :P
PostPosted: Mon May 21, 2012 6:47 am
washed it and took it for a drive :D
PostPosted: Mon May 21, 2012 10:19 am
I hooned a lot, and people applauded
Users browsing this forum: Bing [Bot] and 253 guests
