It is currently Sat Aug 23, 2025 1:20 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 330, 331, 332, 333, 334, 335, 336 ... 568  Next
PostPosted: Mon May 21, 2012 12:59 pm
adamstuart wrote:
Speedwell Racer wrote:
Painted the gear stick boot surround because i was sick of the rusty worn look.
Had some blue left from the engine so used that.
Cheers, Rhys
Missed a spot
Ha Ha :lol:
PostPosted: Mon May 21, 2012 6:37 pm
The Duckmeister wrote:
Sure it's not just flash glare Adam?
its either that or a reflection off something because that white spot is not there.
1977 Leyland Mini Van - Sold
PostPosted: Sat May 26, 2012 8:49 pm
Yeasterday I pulled apart the dirtiest, filthiest, muddiest, sludgiest, grottiest Mini K gearbox I have ever seen. :evil:
It had been so `well maintained'(!) the idler gear had worn through the side of both needle bearings, knackering both the flywheel housing and the gearbox casing. >>> going to the skip.
Why the f did I strip it? I wanted the selector shafts and forks (if good) for another box.. but I dunno why I bothered. :lol: Even the detent plungers were worn flat on top. But the 3-4 selector fork is OK and its shaft is not bad.
PostPosted: Sat May 26, 2012 10:09 pm
Replaced the crappy UK steering rack in the van with a good Aussie/doc reconditioned rack.
I think that's the last one now, so the fleet should be good for another 20 odd years :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun May 27, 2012 5:29 pm
Went for a drive around the northern beaches :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun May 27, 2012 7:12 pm
I also went for a drive. I was stopped next to a MINI at the lights and they didn't even have a peek at my car. I was a bit surprised given how much BMW market the MiNI heritage.
PostPosted: Sun May 27, 2012 7:17 pm
MINI owners... it's all about `them'. 1/2 the owners don't know (or care!) what a Mini is and was. :wink:
I used to wave when they first came out, but after so many wtf! looks I don't bother now.
Latest MINI shapes should be renamed to BIG and BIGGER. :lol:
PostPosted: Sun May 27, 2012 7:20 pm
This space for rent
Nah, they should recycle the Maxi name.. that worked so well the first time around :lol:
PostPosted: Sun May 27, 2012 7:31 pm
Finished off the walnut dash and installed the new wiring loom - just have to work out where the rest of the car is stashed in my mothers garage. REceived my new ripspeed hilo's and rear subby rods. Sick of waiting for the bum of the mini to settle so I am going to force its will to mine :lol: :twisted:
looking for a supercharger rebuild shop in Toowoomba to give the blower a once over.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun May 27, 2012 7:50 pm
I'm ecstatic!! after 19 Years, four owners and years of neglect. I took my '71 Mini Clubman for her maiden voyage! She ran rough and barely stopped, so for a mini IT WAS PERFECT!! Brakes are still spongey just need to bleed properly and needs a good tune but wont be long before its RWC time!!
1971 Mini Clubman 1100
1968 Morris Mini Deluxe 998
http://www.facebook.com/geelongminiclub
"Everybody should drive a Mini, everybody should own a Mini at some point, or you are incomplete as a human being." -James May, about the classic Mini.
PostPosted: Sun May 27, 2012 9:05 pm
Lachie came around and I got my indicators. Woop!
1978 Leyland Clubman
PostPosted: Mon May 28, 2012 4:38 pm
Went to take some photos of the mods I have done recently only to discover my camera and its batteries are in separate postcodes :oops:
And I made up a boot board out of some scrap ply and vinyl. 'Tis nice and bright so it should be easier to find things in there, and no more hessian fluff on everything from the carpet backing that used to line the boot.
My '78 Leyland Mini on flickr
PostPosted: Mon May 28, 2012 8:17 pm
Installed a new weather proof fuse box, ran some new power cables installed the klaxon horn and re crimped all the connectors as quite a few were loose or not crimped at all.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Mon May 28, 2012 8:52 pm
Boxed up all the excess stuff and spares...
PostPosted: Mon May 28, 2012 10:28 pm
made up an adjustable alternator mount so i can easy adjust the fan belt, i am glad something went well for once
Modified a Mitsi Magmum one.
pitty it took an hour to get the pulleys to line up. :shock:
Users browsing this forum: Bing [Bot] and 207 guests
