It is currently Fri Jul 18, 2025 9:36 am
PostPosted: Thu May 24, 2012 7:20 pm
As per the title, are there any advantages in using an A+ 1275 block over a pre A+ (non S) as the basis for a hi-po engine build?
 Post subject: A+ Blocks
PostPosted: Thu May 24, 2012 8:02 pm
um.. The A+ blocks are heavier !
"Let us remove your "SHORTS"
PostPosted: Thu May 24, 2012 8:03 pm
Some might think so, but I don't. :lol:
Many/most A+ blocks had porous castings, were sleeved, and the water jacket not concentric with the bores....
[edit] I dunno if they are heavier, they put ribs on the outside and thinned the block in other places.
PostPosted: Thu May 24, 2012 8:22 pm
No problems with my A+ blocks, but they were post 1990, if that makes any difference.
PostPosted: Thu May 24, 2012 8:29 pm
all the big power engines in UK use A+ blocks.... shouldn't make a scrap of difference
PostPosted: Thu May 24, 2012 8:45 pm
Supposedly the ribbing is meant to help with torsional stiffness, but I guess that really depends on its intended use.
Most A+ blocks have done far less kms/"work", and therefore aren't as flogged out.
"Some" blocks were porous; these were lined from the factory.
If you have one of these blocks and need to bore oversize - larger than the liner/sleeve allows, you'll need to go oversize with these too and that will be an additional cost of course.
What are you going to be doing to the engine?
PostPosted: Thu May 24, 2012 9:04 pm
If you are going for big power try and get a large journal crank, there stronger than most others simply because they are thicker where the bearings sit. Other wise I don't think any type of block is better than another.
PostPosted: Thu May 24, 2012 9:40 pm
Big journal 12G1505 (late 1100S, 1275LS etc) cranks are more likely to crack than the small journal ones, their fatigue life improves if you grind the crankpins down 1/8" and put decent radii in them, so they can flex.
ie, stroke that sucker :P (but crack test it first- many are cracked already).
PostPosted: Thu May 24, 2012 10:01 pm
I have a 1100s block at the moment. Planned build is 0.020 over, 70.2mm south african crank, bmw rs head and turbo. Could say it will be slightly modded. :lol:
Sounds like the block i have will be ok then...
PostPosted: Thu May 24, 2012 10:14 pm
Nothing wrong with an 1100S block for getting high power. 8)
PostPosted: Fri May 25, 2012 4:39 pm
hee hee,,, they use them simply because they stuffed & sold & ruined & thrashed all the early ones they had & hardly have any early strong ones left now :-) so of course they`re going to use A+ blocks for their race engines,,, they have no choice :-)
& yes , if an A+ """isn`t""" sleaved,,, then it probably should be :-)
PostPosted: Fri May 25, 2012 10:02 pm
Didn't the A+ motors have timing chain tensioners too?
Wouldn't this be a... plus? :lol:
You're so square
Baby I don't care
PostPosted: Fri May 25, 2012 10:19 pm
Useful for taking up the chain slack when you line bore an A series. Yes!! :twisted:
PostPosted: Sat May 26, 2012 7:28 am
Matt, does this apply to all A+ blocks, or just the early ones?
Steve
PostPosted: Sat May 26, 2012 10:45 am
i don`t trust any "Non-Sleeved" A+ blocks to be honest
like i said earlier & have always said--> if they are not sleeved then they probably should be
even if they look great & have been running well for years & years,,, & then you go & bore it out,,, & then it shows up it`s porosity...(or rather it "May" show up)
don`t get me wrong,,, i`ve seen heaps & heaps of these things, we used to import hundreds of them every year, pallets & pallets of the damn things,,, so i`ve seen (& still do see) my fair share of them,,, but you`d "RARELY" see a porous 1100"S" block hey?
& yet (of the non-sleeved A+ blocks) i`ve seen almost as many porous A+ blocks than non-porous A+ blocks (almost)
nothing really wrong with sleeving them now-days except for the cost
we are running out of quality 1100"S" blocks & so the A+ blocks will have to be used ... & if they have to be sleeved then so be it,,, at least then we can use them :-)
but yes,,, i must say,,, i`ve seen less problems with the later blocks
