It is currently Wed Jul 23, 2025 2:24 am
 Post subject: 6 Blade metal fan
PostPosted: Fri May 25, 2012 9:45 pm
Hi All
Can any one tell me which way round a 6 blade metal cooling fan goes?
Each blade is riveted to a mounting which is part of the centre piece
Are the blades closest to the radiator or the engine
Many Thanks
Mk1 Cooper S
Mini K Rally car
PostPosted: Sat May 26, 2012 7:18 am
The blades go the radiator side of the centre mounting piece. You should be able to see the centre mounting piece from the engine side.
The fan is "supposed" to run in line with the radiator shroud opening. Check that this fan clears everything before you start it!
Steve
 Post subject: 6 blade metal fan
PostPosted: Mon May 28, 2012 8:42 am
Many thanks Steve
Mk1 Cooper S
Mini K Rally car
Users browsing this forum: XMK870 and 95 guests
