It is currently Sun Aug 03, 2025 6:36 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: Help with a lock nut.
PostPosted: Fri Jun 01, 2012 10:08 am
Hi Guys,
I am after the correct lock nut for the wheels attached.
I am not sure on the brand of wheels or lock nuts used.
The seller did provide a lock nut but its cracked in 3 places and worn down so it just spins when its on the nut..
Can anyone identify what brand / type of nut it is and where in Sydney i can get one from fairly urgently?
The markings on the socket are:
Top: 4A83
Side: Galaxy
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Fri Jun 01, 2012 10:10 am
You could get a machine shop to build up that lock nut socket if you wanted to reuse the lock nuts. Alternatively some butchery may be required if you need to get the wheel off in a hurry.
PS whats with the surgical gloves?
:shock:
PostPosted: Fri Jun 01, 2012 10:14 am
Either sacrifice a socket which is slightly undersized and knock it over with a hammer or take it to a mechanic and they will do the same thing but with their own tools. Lock nuts are a pain in the arse.
WD40'll fix it!
If it don't, use a big hammer!
:shock:
tbh i want to change the lock nuts and the nuts as they are rusty..
Whats the best way to butcher it off?
The gloves are so i don't get road dirt all over my hands :D
Nitrile gloves don't break down to oil and fuel as quickly as latex and vinyl gloves do.
PostPosted: Fri Jun 01, 2012 10:16 am
I might get 4 cheap sockets and try it that way.
:shock:
Do you guys know what thread the wheels use?
i might as well get new nuts.
PostPosted: Fri Jun 01, 2012 10:17 am
once you get them off,,, i have new CNC machined "Stainless" nuts to suit for sale 8)
PostPosted: Fri Jun 01, 2012 10:24 am
I would buy them off you but i am in Sydney :(
and it's friday..
I have tried a 23mm socket and it wont fit.. I think i will have to buy a few sets..
PostPosted: Fri Jun 01, 2012 10:33 am
Success!
I tried pounding it in but it wouldnt budge so i got out the hand held jack and shoved that in the other end of the tire iron and that worked...
I think i need to buy 3 more.
thanks for the help again guys..
This is one big learning process.
PostPosted: Fri Jun 01, 2012 10:44 am
danny_ wrote:
Success!
What, 3 more wheel brace thingy’s? Just clamp the old nut in some mole grips, stand on them and start bashing the wheel brace. If they don’t separate use a bigger hammer. :lol:
WD40'll fix it!
PostPosted: Fri Jun 01, 2012 11:48 am
The nut won't come out :( I have tried hitting it and heating it up..
Off to find 23mm sockets.. This is really fun :/
PostPosted: Fri Jun 01, 2012 2:14 pm
As pdj said go and get a bigger hammer.
PostPosted: Fri Jun 01, 2012 2:59 pm
Thread is 3/8 UNF
They are Contessa wheels, chrome nuts are available from Minisport SA or buy some SS ones off Matt.
Locking wheel nuts on Contessas are a waste of time, as everybody has 3 sets of these wheels anyway. (don't they?) :P
PostPosted: Fri Jun 01, 2012 4:10 pm
Try putting some small hose clamps around the socket to keep it together while you try using it. I had the same problem with an o2 senser socket.
"Let us remove your "SHORTS"
PostPosted: Fri Jun 01, 2012 4:12 pm
I got them all off with a combination of brute force and the air jack.
The super crap 23mm sockets didnt work.. Looks like i have to go back to super crap and return them.
Matt how much are 16 S/S wheel nuts?
PostPosted: Fri Jun 01, 2012 5:06 pm
I have had a similar problem, I once lost my locknut. I just went to a nearby tyre business and they tried a few of theirs until they found one that suited.
Carpe Diem
1967 Deluxe (Bluey)
Users browsing this forum: timmy201 and 95 guests
