It is currently Sat Aug 16, 2025 7:44 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Jun 01, 2012 12:59 pm
That's what Mini Spares calls it.
They appear to be around the 20 pounds mark over seas and that translates into 80 bucks here.
Is this too far gone, or can I salvage it? OR... are they available cheaper than $80 in Aus?
PostPosted: Fri Jun 01, 2012 1:36 pm
Not that I've had experience with these, but surely that looks salvageable?
PostPosted: Fri Jun 01, 2012 1:45 pm
Replacements (made in England) are stainless steel, which is probably a better idea. The common problem is rust from the inside breaking through to the outside. If it's sound inside, it will probably replate successfully.
Another thing you should check is if they make the early multi hole version, like you have.
Al
PostPosted: Fri Jun 01, 2012 3:02 pm
You could get a few sets laser cut and folded from SS, won't cost a fortune. Then sell the spare sets to fund yours. 8)
PostPosted: Fri Jun 01, 2012 5:45 pm
From the SS?
PostPosted: Fri Jun 01, 2012 8:50 pm
Have the one's in your photo's been scrubbed over with steel wool!! It is amazing what this can salvage!!
So I have be told, the new replacements do not fit or work very well, (we don't always believe what we are told), it would be better if you could find someone who has fitted a replacement slide successfully, before you buy one.
PostPosted: Fri Jun 01, 2012 8:59 pm
20 pounds is about $32 at the current exchange rate ...............
PostPosted: Fri Jun 01, 2012 9:02 pm
plus shipping :!:
PostPosted: Fri Jun 01, 2012 9:11 pm
cush wrote:
From the SS?
From Stainless Steel (I think thats what he means)
Wingman
PostPosted: Fri Jun 01, 2012 10:31 pm
Yep SS, aka S/S...
There are lots of places now that will laser cut and bend stuff cheap. :wink:
PostPosted: Sat Jun 02, 2012 6:12 pm
mickmini wrote:
plus shipping :!:
Now now, you two. I'm not starting a "buy local" thread.
PostPosted: Sat Jun 02, 2012 6:14 pm
Cheers, I might try that.
PostPosted: Sat Jun 02, 2012 6:26 pm
Go to bunnings, buy some rust convertor (make sure its got phosphric acid in it) wipe it on with steel wool, wipe it on thick... leave it for 30min... wipe it down with metho and steel wool.
It will be clean, rust free and will take longer to rust next time.. Apart from surface rust yours look fine.
PostPosted: Sat Jun 02, 2012 6:38 pm
Yeah cool.. cheers...
PostPosted: Tue Jun 05, 2012 5:53 am
These strips are not a plain shape, they would have been made with a die so cannot simply be folded up. It would be quite a job to fabricate them.
Al
Users browsing this forum: No registered users and 258 guests
