It is currently Fri Aug 08, 2025 8:14 am
PostPosted: Sun Jun 03, 2012 10:09 pm
Hi all, I have a Clubman with significant front end damage. I also have a very rusty 850 (roof and floor) with a mint front end.
So I have to ask the question. How much trouble would it be to graft the round nose (which I much prefer anyway) to the Clubby?
I am thinking that a cut and shut just forward of the firewall might be the way to go, using the round nose sub frame to hold everything in place for welding.
I am sure it's been done before and I look forward to reading all your insightful and sensible suggestions.
Rod
PostPosted: Sun Jun 03, 2012 10:16 pm
yep. it`s all good & relatively easy to do too
My Targa Tassie rally car was just that
8)
PostPosted: Sun Jun 03, 2012 10:21 pm
Online
Michael B did this front end conversion with an LS, here's his build thread- http://www.ausmini.com/forums/viewtopic.php?t=52628
A panels look so bizarre with no seams!
Looks like a neat job Matt, but don't think it's a small task Rocket
Edit: A Panel, not pillar
You're so square
Baby I don't care
PostPosted: Sun Jun 03, 2012 10:36 pm
I would think it is easier to do with new panels rather than trying to graft on the complete front end all at once?
the differences, apart from the round guards and bonnet, is that both inner guards are different plus you will need to swap the two brackets which are spotted onto the firewall channel and brace against the left and right inner guards. You will also need a rover bonnet and round nose hinges which will bolt straight onto the clubby body hinge brackets.
For the inner guards I usually cut just behind the radiator support as it is easy to access.
But yes it's doable
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
 Post subject: Body Change
PostPosted: Mon Jun 04, 2012 5:13 pm
If one does this conversion,what identity is used on the vehicle? The ID of the Mini Round Nose or Mini Clubman.
 Post subject: Thanks
PostPosted: Mon Jun 04, 2012 5:23 pm
But yes it's doable
Thanks Michaelb. I agree that using new panels would be better but I have a good round nose front end already so I think I might have a go at that.
Your Mini looks absolutely outstanding. I hope I can fix mine up to about 50% of your standard. Did you use a Clubby front sub frame or a round nose one? I haven't checked them side by side for any differences yet.
Thank all
Rod
PostPosted: Mon Jun 04, 2012 5:39 pm
Hi Rod, subframes are mostly the same although I used one from a mini k as my clubman one was damaged, about 25mm out of square as it had been hit in the drivers side front corner.
I will be interested to see how you go with trying to graft a whole front end on in one piece? I think the hardest part would be where and how you join the inner guards. It is also difficult to get the guards to marry up to the curves around the windscreen panel.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Jun 04, 2012 5:43 pm
I used the clubby I'd plate which I modified and welded back on as the top of the radiator surround. Most of the car is a clubby plus I only had the rego papers for the clubby which helps greatly when the time comes for a blue slip and vehicle identification.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Jun 04, 2012 6:26 pm
Best modification you could possibly make! :P :P
PostPosted: Mon Jun 04, 2012 7:27 pm
Delux front meets Clubman.
Easy job - just take your time to fit it up.
PostPosted: Mon Jun 04, 2012 8:24 pm
That looks nice and neat ...
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Mon Jun 04, 2012 9:31 pm
Good info, that. My Clubby was registered when I bought it and was transferred to me so I guess I had better keep the ID right to make it easier when I want to license it again.
Rod
PostPosted: Mon Jun 04, 2012 9:34 pm
[quote="IndigoBlueCooperS"]Delux front meets Clubman.
Nice looking job there IndigoBlueCooperS. Gives me more ideas on where to cut and shut.
What sub frame did you use?
Thanks
Rod
PostPosted: Mon Jun 04, 2012 10:05 pm
Rod,
Subframe was out of a late moke. Cut the bumperbar and sump gaurd mounts of it.
The original one was a hydro (Clubman GT from which I still have the bags :D ).
Users browsing this forum: drmini in aust and 85 guests
