It is currently Mon Aug 04, 2025 4:52 pm
 Post subject: Dead head?
PostPosted: Wed Jun 06, 2012 7:07 am
Hi guys,
I have a problem with my mini. I replaced the lower radiator hose yesterday as the old one had a couple of holes and I assumed that it was contributing to an overheating problem I was having.
I took it for a short drive (about 5 minutes) yesterday and it got to normal temp quite quickly. I let it cool and then checked there was no coolant loss (which there didn't appear to be). So I took it for a longer test drive. Before I knew it, the temp gauge was getting close to red, so I pulled over. Just before I stopped, the car began to run very rough.
I left it to cool by the side of the road for a couple of hours (during which time I have decided the water pump will be the next thing to check as the overheating culprit). When I went back, I checked the coolant level which was still fine, and started her up. Still running like a chaff cutter, and just while idling started to chugg and the revs just got slower and slower and the throttle wouldn't do anything and it stopped.
I fear the worst, ausmini! Has anyone got any ideas or suspicions? I guess I'm kind of hoping you'll tell me my head's not broken :-(
Ben
'77 Leyland Mini Van
PostPosted: Wed Jun 06, 2012 7:26 am
It has oil in it? Serious question.
PostPosted: Wed Jun 06, 2012 7:38 am
Good question. Yes it reads halfway between min and max on the dipstick.
PostPosted: Wed Jun 06, 2012 10:01 am
random but check the plugs are the really black?
PostPosted: Wed Jun 06, 2012 10:44 am
Low oil pressure can cause overheating, and the fact that it got slower and slower until it stops sounds pretty bad to me. It might be a failed oil pump, which means the engine may have seized. If you put it out of gear, try putting a spanner on the camshaft pully and turning it. If it turns, good. It would be easier to turn with the spark plugs out.
PostPosted: Wed Jun 06, 2012 11:38 am
This space for rent
Timing? If it's got lots too much advance it'll overheat real fast and run like a pig to boot...
PostPosted: Wed Jun 06, 2012 11:45 am
sounds like the thermostat was stuffed & wasn`t opening 7 now has blown the head-gasket
maybe????
just a wild guess
PostPosted: Wed Jun 06, 2012 12:17 pm
sounds exactly like that to me too...
PostPosted: Wed Jun 06, 2012 1:17 pm
Me too.... ( Only cause Matt says so)
:D
PostPosted: Wed Jun 06, 2012 3:15 pm
Thanks for the advice guys. Although it had a new thermostat a few months ago, it has been sitting for about 6 weeks without coolant, which could have caused the thermostat to jam up a little I suppose?
What would be your advice from here? I'll try to turn the camshaft when I get home from work. If it turns okay, should I take off the head and have a look? If its just the gasket, though, that wouldn't prevent it from running would it? Or would it be the fact that there would be a vacuum leak causing it to run poorly and conk out? Sorry for all the questions, folks, I really appreciate your advice!
PostPosted: Wed Jun 06, 2012 3:19 pm
I'd pull the thermostat and stick it in a pot on the stove, see if it opens.
If it seems to have a problem, then I'd pull the head off for a looksee.
PostPosted: Wed Jun 06, 2012 3:21 pm
que?? how are you going to do that, and what will it prove?
head gasket failures have a few different symptoms, yours sounds like a pretty classic symptom. It most certainly can and usually does stop the car from running...
a vacuum leak will make it run fast, or idle up and down - where'd that come from?
PostPosted: Wed Jun 06, 2012 3:51 pm
I think he meant crankshaft :wink:
although I see where he got the idea :wink:
Irish Yobbo wrote:
, try putting a spanner on the camshaft pully and turning it. If it turns, good. .
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Jun 06, 2012 6:40 pm
Sorry, my bad. Yeah, if you can get a spanner onto the crankshaft pulley bolt, you can see if the engine still turns. I presume you're saying it stopped and won't turn over? It's a 1-5/16 bolt I think.
PostPosted: Wed Jun 06, 2012 6:48 pm
Might even be worth turing the key and see if the engine rotates still
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
Users browsing this forum: mincs1 and 124 guests
