It is currently Wed Jul 23, 2025 3:58 pm
PostPosted: Sat Jun 23, 2012 1:47 pm
In grams please without bolts.
Thanks heaps.
PostPosted: Sat Jun 23, 2012 2:39 pm
Stock AEG521 rod + cap, 608g I just measured, with bolts out.
2x ARP `BB Ford' rod bolts + nuts, add another 84g.
There are 2 versions of a 521- have caps with, or without cutouts.
This one is without. (but there's not much weight difference).
PostPosted: Sat Jun 23, 2012 8:18 pm
thanks Kev
PostPosted: Sat Jun 23, 2012 8:32 pm
Dr
Would you have a part number for those ford rod bolts?
Thanks
Steve
Dalmeny
PostPosted: Sat Jun 23, 2012 9:18 pm
Dr
Thanks
Steve
ARP's # is 155-6002.
16 to a set, I buy from http://www.vpw.com.au/Category/Index/6680
~$74 a set of 16! + post. 8)
Beats S ones don't it...
Others note-
these are 3/8" bolts, they don't fit 1275 big journal rods which have 11/32" bolts..
PostPosted: Sun Jun 24, 2012 9:19 pm
Dr
Thanks
Steve
Others note-
Thanks Kev
Buy a set and throw the other half on here for $30!!!
Steve
Dalmeny
PostPosted: Sun Jun 24, 2012 9:30 pm
I use them for engine builds, get 2 done per blister pack. 8)
Note their heads are a different shape, but they fit.
Steel spec is same as ARP's S ones, but the flanged nuts are hex head, not 12 point.
PostPosted: Mon Jun 25, 2012 11:27 am
yeah i`ve been using them for about 25 years
PostPosted: Tue Jun 26, 2012 1:51 pm
Just to confirm,
Doc wrote; ARP `BB Ford' rod bolts & then later wrote; ARP's # is 155-6002.
On the vpw site it has, ARP-155-6002 Ford FE rod bolt kit under that # Is this the correct bolt kit?
PostPosted: Tue Jun 26, 2012 3:30 pm
Yes.
FE is a Ford bigblock.
PostPosted: Tue Jun 26, 2012 4:37 pm
Cheers Doc.
PostPosted: Tue Jun 26, 2012 5:29 pm
yeah i`m pretty sure there are a couple of BB ford rod types, hence the 2 types of rod-bolts to suit :-)
PostPosted: Tue Jun 26, 2012 6:29 pm
In Ford terms the FE is not a big block. It is an FE block.
PostPosted: Tue Jun 26, 2012 7:01 pm
Well yeah it's midsize then, :lol: not a smallblock like a 260>289>302>351 Windsor is.
It started out as a 332 in 1958, then 352, 390, 406, 410, 427, finally 428 Cobra Jet).
It's not a small engine, size wise. Weighs 650 lbs...
http://phystutor.tripod.com/stang/engines/fe.html
PostPosted: Tue Jun 26, 2012 7:59 pm
Dr
Thanks
Steve
Others note-
so these don't need to be machined like the set you sold me once?
Users browsing this forum: 1071 S and 82 guests
