It is currently Mon Jul 28, 2025 12:56 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Jun 24, 2012 4:35 pm
http://www.ebay.com.au/itm/1965-Austin- ... 500wt_1156
Check out the exterior pics..........
PostPosted: Sun Jun 24, 2012 4:46 pm
wow, it's got those ultra rate presto chango Morris-to-Austin badges!
PostPosted: Sun Jun 24, 2012 4:49 pm
I wonder if both types of badges are included with the sale
PostPosted: Sun Jun 24, 2012 6:11 pm
In some shots it has a tachometer on the left :? :? And then no tachometer?
Also has no engine fan?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jun 24, 2012 6:15 pm
Yea of little faith.....
This a NZ car - so Austin quite possible and even probable (and if I remember even some Aussie Morris were rebadged Austin for that market (or was that one of those myths ?))
It has the "can opener" drain holes on the gutters - so english style body.....
The BMH Certificate is happy to confirm as Austin as well....
and 1966 Rego papers too....
.. or have I missed something obvious ??? :?: :?: :?:
EDIT:
No engine fan .....
This was raced in the 80s in the 0-1000 class
My race car didn't have an engin efan when I bought it...
Last edited by MINImal effort on Sun Jun 24, 2012 6:18 pm, edited 1 time in total.
PostPosted: Sun Jun 24, 2012 6:18 pm
each pic, there are different body badges
PostPosted: Sun Jun 24, 2012 6:20 pm
I see now.... :oops: :oops:
... I'll just go stand in the corner....
:lol:
PostPosted: Sun Jun 24, 2012 8:54 pm
So its an English import that at some time had a Morris badge fitted that has been swapped back to the correct one for resale .. Its obviously been repainted and retrimmed as well - not unreasonable if it was a racer at some stage..
Big deal.
Pending a proper inspection that confirms it is what is said...its a steal...
Cheers, Ian
PostPosted: Sun Jun 24, 2012 9:47 pm
If your selling a car you should at least have consistancy
PostPosted: Mon Jun 25, 2012 8:51 am
I love that colour and trim combination.
I tell you something else that is odd though.
The seller says it has a 1000cc engine in the description.
Yet the head on the engine in the car is clearly a big bore head.
So it's either a small-bore block with a big bore head on it, or it's a 1275 and they lied to the officials. Or just possibly a 970 block which would be very cool indeed.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Jun 25, 2012 8:59 am
While you are right Brett and it would be good to have consistency, a closer look shows that there is.
There is clearly 2 sets of photos mixed in together, the older set would be those inside with the wipers half way u the screen showing morris badges front and rear as well as no tacho.
The later set has the car outside with the wipers in a parked position, featuring Austin badges and a tacho.
A question to the seller would confirm these observations.
I also noticed this and it is another point that a question should clear up.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Jun 25, 2012 9:08 am
Steve
I would go there if I was serious about owning it. But alas, I am not. :)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Jun 25, 2012 11:12 am
No Servo, regulator in the wrong place, solenoid bracket standard one. Lots of things not quite right but it may well have been an S once.
Al
PostPosted: Mon Jun 25, 2012 6:21 pm
Um, don't you think that the price is a lead indicator??????
PostPosted: Mon Jun 25, 2012 6:25 pm
also papers supplied are a NZ Rego and it does not match the plate on the car
I checked the rego and its a 850..
