I have a CG13DE conversion in the works.
Yes, a Nissan micra 1.3.
This seems to have been a hotly debated topic about the worth of doing it, the way I look at it:
It's 100hp ATW
It's lighter than an A-Series
fits without cutting the body (this is the big one for me)
5 Speeds blah blah
I haven't got the motor yet, but I have been doing a lot of research, it's quite popular in the UK.
The UK produces some, 'interesting' engineering when it comes to subframes.
After the recent discussion about the 4EFTE subframes that hang entirely off the towers, I got to designing my own from pictures of british ones.
Here is what I have:
Nothing here is to a particular scale, but I drew it freehand and tried to keep it to correct-ish dimensions.
Drivers side top spar:
Will have a thick spreader plate, covering as much surface area as possible to spread the load.
Loops around to the front bar, and back under the subframe all the way back to the pick up points on the body. This seems like the sturdiest way to do it.
Passenger side top spar:
I don't want to cut the body, or rad shroud, so it's welded along the inside of the turret (like nigel's vtec frame)
Same as the other side, picks up the front and all the back way to the body mounts.
Between the tower is braced.
You'll also notice the diff on the motor (excuse the crude model) sticks through the web on the back, so it obviously has to be cut around.
I was thinking a good way to reintroduce some strength into this area would be a second bar between the towers, welded along the top of the webbing. Then bend it up and over the diff to meet the top bar.
Could also weld either:
A. Thick plate between the rear 'feet' that bolt to the body, to regain strength
B. Similar to Josh's 4EFTE subframe, weld a bar between the two holes on the rear feet (forgot to model those, oops)
C. Bend a weld a tube to the inside edge of the rear feet, all the way around.
Any opinions and criticisms are welcome, as it's obviously still in planning stages.
Needs more gussets and things, so feel free to mention where you they need to go.
SimonK, wouldn't mind hearing your opinion too
