It is currently Wed Jul 23, 2025 11:42 am
What to do?
Run filters, but no ram tubes. 100%  100%  [ 2 ]
Have ram tubes, but no filter. 0%  0%  [ 0 ]
Total votes : 2
PostPosted: Wed Apr 27, 2005 11:33 pm
I have a 1275 LS, mostly original except for the motor, and i have a 45 DCOE Weber on a 5- inch or 'mid-length' manifold (no cutting, you see) Only problem is, i've been told that i cannot run any ram tubes with an air filter, or i can have the filter, but no ram tubes. HELP! I've just finished the new 1293, but want to have both as i cant afford to ruin the new bore or lose new power with no ram tubes...
Any clues?
PostPosted: Wed Apr 27, 2005 11:40 pm
Sorry Neather
Ram tubes and Socks and cut the fire wall to fit with a Box..
Sorry :?
PostPosted: Wed Apr 27, 2005 11:43 pm
stub-stacks and a filter...
PostPosted: Wed Apr 27, 2005 11:59 pm
Yeap. Install the filter plate, then stub stacks on the filter plates, then the filter. Apparently stub stacks are just as good as proper ram tubes, cept for correct induction length...
I wouldn't run without filters! :shock:
PostPosted: Thu Apr 28, 2005 12:44 am
Stewey... come see me... Ive got 2 new short rams for a 45 weber that will fit inside a ram flo filter.... yours for 50 bucks....
These ones have David Vizard spec radius.... better than all the others.....
Or maybe u could get Chris to make a copy of mine :wink:
