It is currently Thu Jul 31, 2025 6:06 am
PostPosted: Fri Jun 29, 2012 3:26 pm
Picked up a car today. I simply cannot get it to run.
spark seen ok.
seems to be getting fuel.
Compression is a but low at 100 on all four.
I drive it onto the trailer this morning but it felt way down on power.
It's has fired and run a couple of times since but doesn't run for long a is slow to rev.
Any help would be greatly appreciated, wife is hassling me for buying a dud!
PostPosted: Fri Jun 29, 2012 8:26 pm
Get new fuel and drain the old stuff which is probably full of water. Spray carby cleaner into fuel system to release gummed needle valve in float chamber.
 Post subject: OR !
PostPosted: Fri Jun 29, 2012 9:33 pm
Bring it to me I will make it BARK...
"Let us remove your "SHORTS"
PostPosted: Fri Jun 29, 2012 10:14 pm
could be timing... points.... or simply damaged spark plug leads
Got a trailer I can borrow Tony?
PostPosted: Sat Jun 30, 2012 9:42 am
i can probly pick it up for you tomorow John
let me know if you`re stuck , cause i`m on my way up to trickys plae today & i can have an empty trailer on the way back Tomorow if that`s any good to you,
happy to help if you need it bro??? & of course i could certainly make it go vroom for you easy-peasy too :-) :-) :-)
0407 135 656
PostPosted: Sat Jun 30, 2012 3:14 pm
Sorted. Had A fella swing buy today. Worked his magic and got it running pretty quick!
It was points, timing, spark, flooding related.
PostPosted: Sat Jun 30, 2012 3:33 pm
WHAT PRIZE DO i GET???? I guessed it... :P :P :P
PostPosted: Sat Jun 30, 2012 9:12 pm
you won a cold stubby needs to be picked up in person by midday on the 1st July 2012 :lol: :lol:
PostPosted: Sat Jun 30, 2012 10:49 pm
On my way
PostPosted: Sat Jun 30, 2012 10:50 pm
On my way
