It is currently Sat Aug 23, 2025 11:25 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 339, 340, 341, 342, 343, 344, 345 ... 568  Next
PostPosted: Sat Jun 30, 2012 2:44 pm
CARTER_GT wrote:
Mini_Maxx wrote:
SOLD IT!!! Dont know if thats a good thing or not tho, offered 9g as is
:cry: no!
YES!! but i dont want to :cry: :cry: :cry: :cry:
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sat Jun 30, 2012 7:57 pm
Pulled my engine out....again.
The gearbox was popping out of 2nd gear when downshifting and when I was changing up from 3rd to 4th the clutch would slip if I was over 4000rpm.
Got the flywheel cover off ok but couldn't shift the bolts inside there. Agh mini's they are a roller coaster of highs and lows. Today is a low.
PostPosted: Sat Jun 30, 2012 7:59 pm
Yeah tell me about it.
I have to send off another caliper to get repaired because the nipple decided to round its self off the second i put the correct size spanner on it and the thread which connects the brake line to the caliper has also perished.. Stupid aluminium calipers.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sat Jun 30, 2012 8:21 pm
Gave up and called Matt Read to help. Im so glad he lives pretty close to me.
PostPosted: Sat Jun 30, 2012 9:10 pm
STILL messing about with needles, springs and petrol :evil:
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sat Jun 30, 2012 9:19 pm
Got new tyres. :D
PostPosted: Sat Jun 30, 2012 9:49 pm
swap you a set of S calipers!
PostPosted: Sun Jul 01, 2012 9:00 am
I am not sure if thats good or bad :/
I am contemplating getting a new set of 4 pot calipers when i get my tax back as i don't trust these ones any more.
PostPosted: Sun Jul 01, 2012 3:13 pm
I changed my clutch diaphragm back to the old one - turns out the blue dot can't handle all the boooost. The old one is a grey... I think I'm going to have a sore left leg for a few days until I get used to the heavy pedal again
PostPosted: Sun Jul 01, 2012 5:23 pm
I decided to fit a new rubber to the rear window of my Morris 1100 this afternoon.
It took three hours, I don't remember them being that hard. :cry:
I get to do the windscreen seal next weekend. :lol:
PostPosted: Sun Jul 01, 2012 5:54 pm
Drove up to Worthington's MINI for some soup :)
Even went for a drive in a new Bini
Great day! Thanks to Minis on the coast and Worthingtons
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jul 01, 2012 7:47 pm
I swapped out the speedo with a brand new one and still had issues. Got a different cable but the engine was too hot to swap it. Filled the car with fuel and found that the gauge doesn't read anything but 1/4 full :?
I'll put the S speedo back because I don't know the calibration of the new one and all my others are 1408 rev/mile.
While waiting for the engine to cool I aligned the column to the rack centre and put the steering wheel straight.
The car has so many new bits and is generally well built but I have found a few screws/ bolts that are under torqued and the engine is leaking oil a fair bit. Something is wrong with the clutch as I have to pump the pedal to engage 1st or reverse from stationary.
Frustratingly, I have found that the CV boots are made of crappy rubber and are already cracking even though they are just a couple of years old and have done no work :evil:
I managed to adjust the exhaust so the LCB isn't against the subframe so the noise is less.
I don't think I can live with the noise of the Dellorto, man it's loud :shock:
M
PostPosted: Sun Jul 01, 2012 7:55 pm
Rushed around this morning in between kids birthday party’s assembling gearbox.
Realised once I had gear hub, lay gear, bearings, retainer all assembled that I hadn't matched up the detent plunger in the 1/2 synchro hub with the machined tooth on the first gear synchromesh :twisted: :evil: :twisted: :evil: :cry: :cry:
Pulled apart, pushed bearings out and fixed the gear position in 5 mins but lost 2.5 hrs getting back to where I had it. O well live and learn 8)
Mini's I grew up with
Slot car couch
PostPosted: Mon Jul 02, 2012 10:39 am
Started 'straightening out' some of the panels on the paddock van.
Got all the fellas around, provided beers, and watched as the work progressed :D
PostPosted: Mon Jul 02, 2012 12:21 pm
Spent to much money on another car :wink: :lol:
Users browsing this forum: No registered users and 272 guests
