It is currently Fri Jul 18, 2025 6:07 pm
Post new topic Reply to topic  [ 219 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15  Next
PostPosted: Wed Jul 04, 2012 8:12 pm
Hi Kevin
I am not sure what the compression ratio is but possibly 9:1
Then I need to calculate the change by adding double gaskets or then adding in the plate which was supplied with the kit
The plate may be overkill with the current 9:1 ratio
I think I need to do some reading :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Jul 04, 2012 9:12 pm
Just measured the decompression plate, it is 0.070inch or 1.80mm
So will try and work out approx effect on 9:1 compression ratio :?:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Jul 04, 2012 10:00 pm
So with my basic maths, I'm thinking?
Current CR assumed to be 9:1
Recommended CR to be 8:1
Assume total capacity is 1342cc therefore each cylinder is 335.5cc, so combustion chamber capacity is now 41.93cc?
335.5/8 = 41.93cc
For a CR of 8:1 = 335.5/7 = 47.92cc
I'm thinking I need a chamber size of 47.92 to get to 8:1 CR?
I therefore think I need to add 6cc into the combustion chamber?
Assume head gasket = 2cc
I need the decompression plate to be 4cc
My plate is 0.070inch thick so I think the volume of a 2.80 inch bore would be 0.4312cc
Looks close to my recommended 8:1?
Any maths experts want to correct my calculations?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Jul 04, 2012 10:52 pm
let me know if you want me to look up the name of the company that made me a 2mm solid copper gasket. 2mm was the thickest they could do and cost $80
I'm not using it anymore, but not sure if I'd trust it on another motor
PostPosted: Thu Jul 05, 2012 9:26 pm
Most 1275 head gaskets are 4cc not 2cc
4efte powered Clubman
supercharged 998 race car
PostPosted: Thu Jul 05, 2012 9:44 pm
Yes, I'm thinking that maybe 2 head gaskets might be the way to go?
But first I will do a few less dramatic options.
And if all else fails then it might be the EFI path :roll:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Jul 06, 2012 12:16 am
Google this " minihead app"
App works well with common fields or enter your own.
Now with 2 extra ports!
PostPosted: Fri Jul 06, 2012 2:20 am
Would the fact that the carby is a mile from the head (and so far down low!) have any effect?
It doesn't seem right from an engineering sense.
Yeah I understand when it's under boost it's a different situation but with your issues at idle it just seems all too odd!!
- sure it is under vacuum still, but it's a long way to suck all that fuel up and in... i dunno... just doesn't seem like a nicely engineered kit to me. :?
PostPosted: Fri Jul 06, 2012 7:31 pm
Hey willy, no prizes for stating the bleeding obvious :shock: :roll:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Jul 06, 2012 7:52 pm
You could always bend up some more pipe so you can stick the carburettor up higher.
PostPosted: Fri Jul 06, 2012 8:03 pm
I'm sure he's already thought of that Morris, but wants to try a few different things first.
PostPosted: Fri Jul 06, 2012 8:07 pm
You could run a customized bonnet to house the carburettor and air cleaner too if you run into clearance problems.
Tyson.
PostPosted: Fri Jul 06, 2012 8:10 pm
You could :wink:
Unfortunately there is very limited space under the bonnet, hence the location of the carby
I think EFI is the way to go, just need to save up again :lol:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Jul 06, 2012 8:47 pm
Tyson.
Here we go again.... :lol:
PostPosted: Fri Jul 06, 2012 9:10 pm
Really? By the look of it you could fit the carby anywhere between the current location and the blower just by shortening the pipe and moving the washer bottle. :roll:
