It is currently Thu Aug 07, 2025 9:35 pm
 Post subject: How can I fix this?
PostPosted: Sat Jul 07, 2012 5:45 pm
Whilst sanding back the engine bay ready to paint I came across this nice surprise....
Thoughts???
PostPosted: Sat Jul 07, 2012 5:48 pm
Looks like its been welded up before....
I'd put a new (good) Subframe in.
Dicko
PostPosted: Sat Jul 07, 2012 6:04 pm
Yep -plenty of good subframes lying around. Just replaced it - makes it easier to do a good engine bay job with the subbi out. Your mostly there anyway.
Where are you ????
PostPosted: Sat Jul 07, 2012 6:40 pm
Sam, I have a `68 Moke one you can have for nix if you come pick it up. :wink:
They are the same, except for a few extra attachment points for the sump guard etc.
PostPosted: Sat Jul 07, 2012 7:22 pm
Sounds great Kevin!
Scared me a bit realising I'd been driving pretty hard with the front suspension barely attached!
Easy job to chuck it in with the engine out?
PostPosted: Sat Jul 07, 2012 7:25 pm
Yes it's pretty easy.
PM sent.
PostPosted: Sat Jul 07, 2012 7:34 pm
I found a crack like that on mine after i got it sandblasted. Luckily i was seam welding it all anyway so it didn't make too much extra work.
Good as new now 8)
Dusk Blue
1964 850
PostPosted: Sat Jul 07, 2012 9:08 pm
weld it up, add straps going from the top and down the side
PostPosted: Sat Jul 07, 2012 10:00 pm
The main reason I'd replace it as the crack is all the way around. Hard to get a welder in there without removing the subby anyway...
PostPosted: Thu Jul 12, 2012 1:39 pm
Mine has cracked as well. Luckily it's not all the way around. My mechanic is going to weld and brace it :)
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat Jul 14, 2012 6:35 pm
What are you guys bracing it with?? Is there some kind of special brace or just a shed knock up to do the job
