It is currently Sun Aug 17, 2025 3:45 pm
Post new topic Reply to topic  [ 84 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Jul 10, 2012 9:45 pm
You know there's such thing as over cooling?
I think mine is currently over cooled with the alloy radiator :shock:
Never gets up to normal a the moment :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jul 10, 2012 9:49 pm
I guess you could say you were over-compensating.
PostPosted: Tue Jul 10, 2012 10:13 pm
Yeah i do..
I would also like to try and extend the life of my engine parts and keep a good engine oil viscosity.. The oil pressure in my last mini like to drop down to 20psi after the motor warmed up.. I prefer the 60psi i have now..
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Jul 10, 2012 10:19 pm
danny_ wrote:
Yeah i do..
If your engine is rebuilt right, you should have ~70psi hot, on the freeway without a cooler.
Even with cheap oil (Valvoline XLD Classic 20W/50 or KMart KMX 20W/50).
Both my 1412 and 1360 do.
Cooler is fine for track use, for anything else it is overkill. Mine is sitting on the shelf.. :P
PostPosted: Tue Jul 10, 2012 10:27 pm
danny_ wrote:
Yeah i do..
Well my car was primarily built as a track/fun day car 8)
PostPosted: Tue Jul 10, 2012 10:30 pm
Better hope those brakes work...
PostPosted: Tue Jul 10, 2012 10:34 pm
No need for hope.. I know they work.. They work well.
PostPosted: Wed Jul 11, 2012 11:19 am
Untill metal shavings break the seals right???
PostPosted: Wed Jul 11, 2012 2:52 pm
Still why hope when you can panic...
PostPosted: Wed Jul 11, 2012 3:27 pm
There's not really enough room between the pistons and bore for these shavings to get to the seals.
They might jam a piston, but I doubt it.
Still, I would have changed the seals too, they ain't expensive. :wink:
PostPosted: Wed Jul 11, 2012 3:28 pm
[quote="drmini in aust" I would have changed the seals too, they ain't expensive. :wink:[/quote]
I was quoted $370 for a brake overhaul which included new seals..
PostPosted: Wed Jul 11, 2012 3:54 pm
I was quoted $370 for a brake overhaul which included new seals..[/quote]
4 pot seals are worth $21.46 a side + GST. The rest is labour, and gravy. :lol:
Fitting them is not rocket science.
PostPosted: Wed Jul 11, 2012 8:13 pm
I'm thinking if I gave a registered brake shop a caliper and asked them to repair as per Danny's then they should repair it to a safe condition. This should include removing any metal filings from the work carried out to perform the repair. I would also expect them to advise on the overall condition of the calipers including the seals.
This is what I expect and have received from my regular brake shop at Brookvale.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Jul 11, 2012 8:22 pm
I asked them to remove the metal filings (first brake shop) and he said he will try his best but you might find a few small filings.. I also asked them to do a pressure test on the brake calipers to check the seals were fine and the pistons working... I don't think he did them to be honest.. i was slugged $25 each.
The 2nd brake shop in Penhurst removed all the metal filings and took out a piston to vacuum out all the filings closest to the repair area.
PostPosted: Wed Jul 11, 2012 8:24 pm
You are kidding right?
Users browsing this forum: No registered users and 357 guests
