It is currently Mon Aug 18, 2025 9:01 am
 Post subject: Temp gauge
PostPosted: Tue Jul 10, 2012 9:29 am
Is there a best way to determine what's wrong with a temp gauge? I have changed the dash over and the gauge has not worked in either of them .
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
PostPosted: Tue Jul 10, 2012 2:38 pm
Start by shorting out the sender unit wire onto the engine block. The gauge should read maximum.
If nothing changes then check the gauge has power. The circuit board on the clubman instrument cluster isn't the best of things and the traces break sometimes, so check it for continuity.
If the gauge reads maximum when the sender unit wire is shorted out, but doesn't work when the sender unit is connected, then it may be the sender unit at fault, which is not uncommon.
PostPosted: Tue Jul 10, 2012 9:52 pm
Thanks, I'll give that a go :)
1976 Mini SS
1976 Mini SS Shell
 Post subject: Temp Gauge.
PostPosted: Thu Jul 12, 2012 6:09 am
And if your Printed Circuit is no Good come to me for a new one.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 311 guests
