68Rusty wrote:
Thanks Kevin,
I have the rubber seals, but I guess people assembling without them over the years causes these sort of problems, I will use some sealer as well as you suggest.
The extra greasing points sound like an excellent idea. I think I will pull long shaft out and drill and tap some from the side for both front and back bush areas. (edit; just realised they may not be able to come directly from the side. I will have to have a look)
I selected the best combinations from the parts I have but maybe some time in the future I may also need to do as you have by welding and refacing them to suitable size. Seems the bush holes in the remote casing and hole in box casing are the ones now most responsible for the remaining slop in the gear stick, boring and pressing bronze bush in is probably next best solution but that’s probably getting a little pedantic I guess.
I always replace the 2 bronze bushes in the diff housing.
You can buy them from the usual suspects but I get a 1/2" bush 2" long from the local bearing shop and cut it in half. Price is about 1/2, too.
To get the old bushes out I screw a 9/16" UNF tap into it, then use a drift + BFH to knock the tap plus bush out. Rinse and repeat for the 2nd one.
A 14mm spark plug tap will work for this too.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
