It is currently Sat Jul 26, 2025 11:16 pm
 Post subject: help me stop
PostPosted: Wed Jul 18, 2012 5:06 pm
Ok so over the last few days my breaks have been getting worse. I went from having a pedal to having to pump it a few times then getting pedal to now absolutely nothing.
Tried bleeding them and cant even get that much fluid pumping through with no change in the pedal. Soooo
Is my master cylinder gonskies?
Could I put a kit though it or just buy a second hand cylinder somewhere as someone has to pay off our wedding so a newbie is out of the question atm.
Cheers Pete.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Wed Jul 18, 2012 5:17 pm
I overhauled a master cylinder , the kit was about 27 dollars. That was a clubbie one. Theyare fairly easy to do.
PostPosted: Wed Jul 18, 2012 5:35 pm
probably start by disconnecting the lines from the MC and fitting plugs to it, then pump the pedal, if you still have the same feel to the pedal than it is your MC, otherwise could be a damaged line or wheel cylinder.
PostPosted: Wed Jul 18, 2012 6:17 pm
Cheers I will give it a go.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Wed Jul 18, 2012 6:54 pm
I would un do the brake like from the MC and get someone to pump the pedal once or twice to see if you get any fluid getting pushed up.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Wed Jul 18, 2012 7:54 pm
put a bleeder in it :D
PostPosted: Wed Jul 18, 2012 7:55 pm
Will it accept a bleeder?
You could be like me and just put in some metal shavings in the brake line..
:shock:
PostPosted: Wed Jul 18, 2012 8:00 pm
:shock:
yep, a 3/8" UNF bleeder, same as what's in a disk brake caliper - not much help if you only have drums, but they're cheap
PostPosted: Thu Jul 19, 2012 10:48 am
It would be good to check the mc by itself, as Paddy and simon k say. What kind of cylinder is it? It could be the bias valve as well - they're very easy to fix once you know how.
Remember to check the cylinder walls for pitting or scoring before rekitting it. If the walls are damaged, you can replace the mc, or get it sleeved in stainless steel. SS is probably the better option, because it won't happen again, and there are some quality issues with newer MCs.
PostPosted: Fri Jul 27, 2012 7:14 pm
Ok problem fixed, mc just needed a kit put through it. Suzispares $35 karcraft $8.50 hmm which one do you think i got :)
So now I can stop.
Im not a fan of help being asked for and no outcome posted once fixed.
Cheers Pete
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Fri Jul 27, 2012 9:40 pm
COME ON... if you don't know what you are doing, get someone to fix your brakes....
"...as someone has to pay off our wedding so a newbie is out of the question.."
So how much is your wife .. or the rest of your life worth???
Think about it,
Ian
PostPosted: Fri Jul 27, 2012 10:06 pm
Hmm as previously stated brakes are fixed. I put a kit through the mc today. I prefer to try to fix things myself as It's a way of learning. :roll:
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Fri Jul 27, 2012 10:08 pm
Think about it,
Ian
Really? This again?
How else is he supposed to learn?
I learnt doing my own brakes.
PostPosted: Fri Jul 27, 2012 10:38 pm
He must be one of those lucky ones who was born with the gift of knowing everything. Or just has the money to pay someone else to build or fix his own car.
This car I have built from the ground up. It's my first rebuild and i have done it all, cut weld screw hammer pull push paint etc.
I have learnt Alot from my father inlaw who has helped with it all along the way as he has been there done that. And someday I hope to spend some time with my son building and teaching also.
But all that said if I see you broken down on the side of the road I will gladly pull over and pull my toolbox out and help you get on your way cos that's just the kind of guy I am, I prefer to help rather then hinder.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sat Jul 28, 2012 9:25 am
that right there is the difference
if you have someone with know-how & experience helping , then it`s pretty cool
but on your own with no knowlege or experience,,, well it`s just down-right dangerous
move along, nothing to see here :-)
Users browsing this forum: Bing [Bot] and 98 guests
