It is currently Tue Aug 05, 2025 7:02 am
 Post subject: Mini spares Linkage Kit
PostPosted: Sat Jul 21, 2012 10:50 am
Anyone have any photos on how these are set up?
I really don't think it should be as hard as it seems!
PostPosted: Sat Jul 21, 2012 1:35 pm
Got a link so we can see what it is?
PostPosted: Sat Jul 21, 2012 2:56 pm
http://www.minisport.com.au/images/c-aht773.jpg
I can get it to the stage shown but no idea how I connect the bar to the weber throttle arm or the accelerator cable!
PostPosted: Sat Jul 21, 2012 3:43 pm
Here's mine- bit hard to see with the hoses, I'll show you tomorrow.
PostPosted: Sun Jul 22, 2012 10:30 pm
any tips on where to go from here?
i.e. attaching the vital part that is the throttle lever and a good place for the spring?
PostPosted: Sun Jul 22, 2012 10:55 pm
I tossed mine and used a Weber wheel.
(Made by Redline IIRC)
Lindsay Seibler (Pistons Auto) has aluminium ones made up which work an absolute treat and look great too.
8)
PostPosted: Sun Jul 22, 2012 10:59 pm
PostPosted: Sun Jul 22, 2012 11:09 pm
That looks amazingly simple compared to this. Surely this can be hooked up though? It comes in a kit ready to go!
PostPosted: Sun Jul 22, 2012 11:12 pm
The L-shaped cable bracket is meant to be held onto the inlet manifold with those two black screws. Your manifold doesn't appear to be made to suit. Pics shortly....
off to shed in the freezing cold....
M
PostPosted: Sun Jul 22, 2012 11:17 pm
Ah k I just grabbed some bolts from my collection..
The kit came with the manifold...that would be outrageous if it didn't fit. I presumed the bracket would actually be held in place by the manifold studs?
Cheers mate
PostPosted: Sun Jul 22, 2012 11:34 pm
Ok, I'm back,
Here are a few pics:
See how the bracket is screwed into the top of the inlet manifold flange.
Return spring visible here.
PostPosted: Sun Jul 22, 2012 11:39 pm
Really appreciate that Mokesta, helps me alot to understand what I'm aiming for.
I bought the throttle lever from weber performance as its description said of was designed to work with the threaded rod and knuckle joints but I see no way of attaching these together :S
PostPosted: Sun Jul 22, 2012 11:41 pm
Ok, mine is a different brand of kit.
Really I think that these are a bit of a flog. You'd need something like this for twins but really, for a single a decent cam arm and rigid cable bracket are all that are really needed.
Mine is as purchased so I don't know the kit brand.
M
PostPosted: Mon Jul 23, 2012 12:29 am
Alright everything's sorted besides the spring location which should be pretty easy.
Cheers for the help.
PostPosted: Mon Jul 23, 2012 12:46 am
Can anyone advise me for or against grinding a small slice into the cross bar of the linkage to make a snug fit for the return spring?
And can anyone suggest a way to make this a more suitable fit of the cable holder? The split pin hole is far too far out.......
