It is currently Mon Jul 28, 2025 3:23 am
PostPosted: Fri Jul 27, 2012 9:37 am
I dont care i just want to buy one to convert from rover set up back to previous set up.
have been told it is Cooper S, wider 5/16" brake pedal.?? seems like a rover set up to me?
PostPosted: Fri Jul 27, 2012 9:40 am
On phone so can't check link but both the cooper S and mini matic had the bigger brake pedal.
PostPosted: Fri Jul 27, 2012 10:10 am
Not sure about the pedal being bigger, but it could be
I was under the impression the brake arm was thicker, so it wouldn't bend under heavy braking.
Matic's also got the same pedal box
You're so square
Baby I don't care
PostPosted: Fri Jul 27, 2012 10:15 am
Matic and S pedals were just thicker, not bigger.
S pedal sits higher than a Matic one though. But a Matic one works fine with S brakes (I run em).
Matic got a throttle pedal with a bigger pad than all the others too.
PostPosted: Fri Jul 27, 2012 2:14 pm
Are Pedal foot pads square or sort of 'diamond' square shaped?
I think all the later pedals (non square) went to thicker material for pedal blade?
Sir Alec! we are not worthy!
PostPosted: Fri Jul 27, 2012 2:30 pm
Square pedals on the S/Matic pedal box
You're so square
Baby I don't care
Users browsing this forum: Bing [Bot] and 90 guests
