It is currently Thu Jul 17, 2025 7:42 pm
Post new topic Reply to topic  [ 236 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
PostPosted: Tue Jul 31, 2012 9:54 pm
Die Die Die!!
hey all, thought i should introduce my moke, i havnt received it yet but should be here within a week.
its a 1977 Leyland Moke, the idea is to install a Daihatsu Sirion Engine, then drive it for a bit, then strip it and paint it and reinstall everything
some pics for the time being..
and the Sirion Engine (installed in a Clubman)
PostPosted: Wed Aug 01, 2012 7:58 am
Good luck with the Moke, hope it all comes together nicely for you!!
Tricky
PostPosted: Wed Aug 01, 2012 5:58 pm
Should be a cool little conversion, how do they go?
PostPosted: Wed Aug 01, 2012 6:58 pm
Die Die Die!!
Should have similar power to a mild 1275 I believe, and of course it's a 5 speed
PostPosted: Wed Aug 08, 2012 7:07 pm
Ive driven the van with the sirion motor in it (was the brothers) Went fine but its only a 1L 3 cylinder motor.
If you have the subframe and motor from Lachy (sorry about the spelling) heaps was spent on fixing alot of oil leaks ect... So hopefuly you shouldnt have to worry about that, it was only he stupid alternator mount that kept cracking. Hopefuly we sorted that too in the end
Life's a garden.... Dig It!
PostPosted: Wed Aug 22, 2012 2:33 pm
Die Die Die!!
so the Moke arrived today, so heres some more pics of it
some nitwit has mounted the radiator in sidways, and the front panel looks like its removable ? or been poorly installed? (does it normally have the reinforcing bars ?)
the whole car seems to be rust free though,
and the wiring looks a bit of a mess, with snipped wires everywhere
PostPosted: Wed Aug 22, 2012 4:24 pm
Looks like they've even made some sort of system for the same fan hub... Must have been a fair effort moving that radiator
PostPosted: Wed Aug 22, 2012 5:47 pm
And not the worst thing you could do. Greater surface area, forward facing and a fan that works based on water temp not engine speed certainly can't hurt.
PostPosted: Wed Aug 22, 2012 6:15 pm
Die Die Die!!
It's actually hooked up to a switch not a thermo sensor ( although that shouldn't be too hard to do) its not stayin anyway, should have the sirloin engine in a week or two
PostPosted: Wed Aug 22, 2012 6:19 pm
I think from memory you might be able to fit something up front, with the sirion engine fitted. Ohh but the was in a clubby so maybe not a moke
PostPosted: Wed Aug 22, 2012 7:12 pm
Die Die Die!!
im really hoping so, i think a standard honda radiator will fit.. but we will see, it wont be easy but i have confidence
PostPosted: Thu Aug 23, 2012 8:10 pm
Sirloin engine -I guess that would be nice and beef!! :wink:
PostPosted: Thu Aug 23, 2012 8:40 pm
Auto correct strikes again
PostPosted: Thu Aug 23, 2012 11:02 pm
Die Die Die!!
that will teach me for using my iphone.. and perhaps for the forums not being tappatalk compatible..
PostPosted: Fri Aug 24, 2012 7:27 am
I like the cupholder
Users browsing this forum: Bing [Bot] and 9 guests
