It is currently Tue Jul 29, 2025 3:02 pm
 Post subject: Back fire through carby?
PostPosted: Sat Aug 04, 2012 1:38 pm
How bad is it when the engine backfires through the carbies? I've only noticed it at idle when the throttle is hit a certain way. Am I right to keep driving it with out worry of a major internal engine failure until I get it tuned?
PostPosted: Sat Aug 04, 2012 1:43 pm
I'd be more worried about the engine bay catching fire.
What have you got behind the carbie insulation wise?
PostPosted: Sat Aug 04, 2012 2:15 pm
`sneezing' it's called, usually is due to a lean mixture above idle;
accelerator pump not working (Weber etc) or, no or too thin oil in the dashpots on SUs.
PostPosted: Sat Aug 04, 2012 7:52 pm
I'm only guessing that it's the motor you just put in??? Just a remote possibility, but it could also be sticky inlet valve if engine hasn't run for a while, if so it'll free up.
PostPosted: Sun Aug 05, 2012 10:09 am
1310/71 It doesn't have any insulation behind the carbies just the pipercross foam filters.
drmini It's running 1" 1/4 twin SUs, I actually think the oil is to thick.
peterb Your correct about the engine, it came out of a running car then sat in my shed for a few years before getting dropped in and hooked up. So far it's got about 120km on it since installation.
So theirs no real threat of it going bang too soon, I understand super lean engines can burn out pistons and heat the engine up more than normal correct?
PostPosted: Sun Aug 05, 2012 11:34 am
I had the same and it was a blocked jet and fuel line..
PostPosted: Sun Aug 05, 2012 3:10 pm
On twins? would that cause one or both to backfire?
PostPosted: Sun Aug 05, 2012 3:41 pm
set too lean in mixture
cold start with no choke
sticky/dirty/grotty carby pistons & bells
too light (or low level or no) oil in dash-pots
low float level
do you want more??? or will that lot do for now?
bad condensor
ignition far too retarded
poor ign coil reserve
burnt inlet valves/seats
leaky manifold gasket/carby base gasket
i can go on if you like???
&&& add any of & all of the above in any combination will do it too
Users browsing this forum: fuzzy-hair-man and 111 guests
