It is currently Thu Aug 07, 2025 9:34 pm
PostPosted: Fri Aug 03, 2012 2:21 pm
Hi,
My Traveller originally came with hubcaps like this:
The trim bit with the airholes around the edge is integrated with the cap in one piece. I believe the same caps were used on Cooper 997/998.
How in craziness do you remove them without damaging the wheel or cap? I recently purchased a good used set and I don't want to screw them up.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Aug 03, 2012 8:08 pm
Brett, the original mini lever is the best tool for these, you have to gently bend the outer trim to get the flat pry bit of the tool in near to the centre cap, twist a bit and BOING! Off she comes, try to catch it before it hits the deck! :lol:
Sir Alec! we are not worthy!
PostPosted: Fri Aug 03, 2012 8:18 pm
i run with these best way ive seen it done slip ur polishing cloth around the back and out the next hole and pull wham they pop off no damage to hubcap or paint on rims
if you need any i have a good stash of them
PostPosted: Sat Aug 04, 2012 7:58 pm
Bit hard to describe but you put the tool through 'vent' hole and between cap and wheel as close as possible to retaining bump on rim, then lever it off by moving lever towards centre of wheel. Sounds arse about I know but they come off no worries.
PostPosted: Mon Aug 06, 2012 1:21 pm
Location: MinisintheGong [Somewhere on the South Coast]
If it helps I can confirm that the two piece hubcap / dress rim were a standard item of the 1964 Short-stroke (998cc) Australian Morris Cooper. Similar effect to the ones in the photos on this thread. Mine had them back in the day.
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Mon Aug 06, 2012 1:24 pm
Thanks for the suggestions people.
I will have a bit of an experiment with the worst cap and teach myself to do it properly based on your suggestions.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Aug 06, 2012 2:06 pm
Are you saying they were different to the ones pictured :?:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Aug 06, 2012 2:33 pm
I have a 64 cooper in restoration (very slow!) it has the one piece caps like those pictured by BNicho.
I know PantherSteve has a 64 Cooper as well, what does yours have steve?
PostPosted: Mon Aug 06, 2012 2:40 pm
Since we are discussing the originality of the caps...
I read in one of my Mini books there were two types of these caps. Ones with kidney-shaped slots and ones with semi-circular or "half-moon" slots like in the picture above.
Perhaps what the author meant was the two-piece ones had the kidney slots?
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Aug 06, 2012 2:46 pm
Mine didn't have any with it but I did know about the different shaped cut outs. However I thought both shaped cut outs are in one piece trims. I have not seen two piece trims :?:
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Aug 06, 2012 3:12 pm
Come on Graham you need to get a move on or it'll rust away
PostPosted: Mon Aug 06, 2012 3:41 pm
I'm not sure about kidney or D shaped holes (I thought that style were all the same), but the early cars to 1961 had rectangular cutouts.
My Traveller has these, but they aren't correct. They also aren't very good, they have these terrible sharp claws that gouge into the paint on the rims and do immense damage.
The two part trims are a normal hubcap with a dress rim around the outside. I thought they were aftermarket, but I have been wrong before.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Aug 06, 2012 3:53 pm
I'm pretty sure the 2 piece ones were aftermarket.
I remember the 1 piece factory ones hanging on the wall at my local BMC dealer as an accessory.
PostPosted: Mon Aug 06, 2012 6:12 pm
Dress rings were available as a BMC accessory but I think they were only the outer ring type.
The three down the left hand side of this scan are all 10" Mini ones.
PostPosted: Mon Aug 06, 2012 10:45 pm
They were two piece held in by the standard hubcap. The kidney shape like the first photo but I think slightly different. Mini King had three of them there last I visited about 2-3 months ago.
The variable that still exists, I now realise is that I bought the 64 Cooper in 1967 and cannot say that they were factory. I had a friend that also bought a 997 with the same dress rims. We both discarded them when fitting wider wheels.
Users browsing this forum: watsupskip and 105 guests
