It is currently Wed Aug 06, 2025 12:17 pm
PostPosted: Mon Aug 06, 2012 6:41 pm
What parts a specifically Moke.
What I am trying to figure out what is unique to a Moke.
other than the obvious
eg gear boot, body, rear trailing arms
Ta
Kiwiinwgtn
PostPosted: Mon Aug 06, 2012 6:54 pm
Just about everything else that you've listed.
:shock: :lol:
Bumpers won't fit
Oh wait, that's obvious.
Um..... what did you have in mind???
Pedal box is different
If you want bumpers, you need to weld on the mounts, or get one with mounts
That's all I can think of
You're so square
Baby I don't care
PostPosted: Mon Aug 06, 2012 6:58 pm
Fuel tank
Side light
Rear lights
Seats
Floor mats
Roll cage
And you may have difficulty fitting a Moke grille to a Mini :lol: :lol: :lol:
PostPosted: Mon Aug 06, 2012 7:06 pm
So are the motor, box are the same, brakes, suspension (other than rear arms)
My investigations have found the following as special to the Moke.
Body
Rear Lights
Rear Trailing Arms
Pedal Box
Gear Lever Boot
Wiper Motor
Bumpers
Sump Guard
Screen
Seats
Dash
Have I missed anything
Ta
Bernard
PostPosted: Mon Aug 06, 2012 7:11 pm
Diff ratio.
Gearshift.
Bonnet. :lol:
PostPosted: Mon Aug 06, 2012 7:13 pm
If you want to be completely correct the rear subframe has extra strengthening too.
Also the rear suspension trumpets are van items.
If you are doing a little-wheeler you can use more Mini parts.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Motor and boxes are much the same, except for diff ratio on the bigwheel ones. They mostly run a 4.13. For fitting 10" wheels to these most folks go for a 3.44 instead (if using a 1098 or 1275).
PostPosted: Mon Aug 06, 2012 7:46 pm
Hand brake cables are a different length I think.
Demister ducts
Wiper assembly
Wheels
Sump guard
Wheel arch trims
Fuel level sender
Floor mats
Rear view mirror and wing mirrors
Rod change to gear box links (shorter on moke)
Exhaust (to go around rod change thing)
Rear brake pressure limiting valve
Choke and heater cables
Dash switches
M
PostPosted: Mon Aug 06, 2012 8:41 pm
wow there is quite a difference then. more than I realised.
PostPosted: Mon Aug 06, 2012 8:45 pm
Per adamstuart - Moke front subframes have bits welded on to mount the bumpers, but 2 different kinds depending on the bumper style. Front subframes were also predrilled to fit the sumpguards.
I only know this because i was looking at them at Mini King last week and John explained what all the bits were (thanks for another educational morning John)
michael
PostPosted: Mon Aug 06, 2012 9:12 pm
I would say ask on mokes inc. but to them a moke has nothing what do ever in common with a mini...
PostPosted: Mon Aug 06, 2012 9:53 pm
Kiwiington
There isn't a load of difference, really.
For the most part, you could reshell a mini into a moke.
What everyone has listed is true, and most parts are obviously different - Lights, tank, switches and such.
But if you aren't going for concourse, then you can fit pretty much everything.
Handbrake cables wise, if you are using the longer moke arms, you can get moke cables from Karkraft.
If you want to use mini trailing arms you will need to get custom cables made up, or buy 13" moke ones and shorten to suit.
You're so square
Baby I don't care
PostPosted: Mon Aug 06, 2012 9:54 pm
THIS! :lol:
PostPosted: Mon Aug 06, 2012 9:58 pm
willy wrote:
THIS! :lol:
"But this one is a Morris MINI Moke"
"Yeah, well, ours aren't mini's"
You're so square
Baby I don't care
Users browsing this forum: Gambo and 92 guests
