It is currently Sun Aug 03, 2025 11:39 pm
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Aug 10, 2012 1:57 pm
peterb wrote:
danny_ wrote:
peterb wrote:
danny_ wrote:
My speedo!
doing 20km/h speedo is fluttering from 110 km/h to the fuel gauge... the speedo looks like one of the newer ones too.
Sometimes the seal in speedo drive at gearbox leaks and cable 'pumps' oil up outer and into speedo head, gunking it up. Tell tale is oilyness around back of speedo.
I am finding quite a bit of oil.. well mostly grease type stuff on the cable but not on the back of the speedo its self.
How hard is it to change the seal?
The car is at the mechanics atm but he reckons the speedo needs to be re calibrated, I will ask him to check the speedo drive seal tomorrow.
you can get the drive out in situ, bit of a fiddle. tiny seal in fitting where cable goes on box. You could try cleaning "insides' of speedo using contact cleaner or the like. What sort of speedo is it? Old centre one or leyland 'front of driver'? You can take them apart, to very carefully clean.
Note when you buy a new speedo cable these days they are usually bone dry inside, and sometimes come with free rust.There is no seal in the speedo head.
Recommended practice has always been to grease the inner cable (preferably with molygrease) before fitting, but leave the top 150mm dry.
If you grease the whole thing, grease often ends up in the speedo head causing symptoms as described.
PostPosted: Fri Aug 10, 2012 3:17 pm
It's the older center one with KM/H and mph in small text,
I am going to pick the car back up from the mechanics tomorrow and i will sus it out once i get home.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Fri Aug 10, 2012 4:43 pm
how do you place grease in the cable?
PostPosted: Fri Aug 10, 2012 4:46 pm
Pull the inner cable out the top. :wink:
[edit] preferably before fitting but can be done afterwards.
PostPosted: Fri Aug 10, 2012 5:03 pm
That will cause the cable to fluctuate as well wont it??
PostPosted: Fri Aug 10, 2012 5:11 pm
last few days car has turned over slowly. Yesterday went to go home from school, turned over once slowly and then wouldnt work.
Went home grabbed a new starter motor and went up and swapped. Turned over and started a breeze. 38yrs from a starter motor motor is pretty good i suppose.
Then today heard a banging noise under the car. both exhaust mounts have broken and so exhaust is just hanging there. Project for the weekend.
Brenton
PostPosted: Fri Aug 10, 2012 7:08 pm
Nope not really, unless kinked, but if unlubed it'll squeak and give you the sh!ts.. as it did me.
:lol:
PostPosted: Fri Aug 10, 2012 10:06 pm
:lol:
Ausmini quote of the year there kev hahahaha :lol:
 Post subject: oh the pain
PostPosted: Sat Aug 11, 2012 8:35 am
A: Did the loose front wheel thing. Drove 10k to the city and return home, wheel fell off 50m from my drive way, rolled up the gutter and onto the footpath nearly hitting a person. Grinding to a halt and making apologies is a solid memory hook. I also have a 20m gouge on the road as a constant reminder. Now my mantra is "finger tight while up, bloody tight when down"
Needed a RWCert for a clubman once and the drivers footwell had some rust through spyholes needing to be covered. Well used black bitumen body deadener and on the bigger one cut some tin to pop rivet over before more deadener was to go on. Problems with brain thinking as 1:battery still connected 2:working in sequence ment body deadener already covering everything 3: Poprivets need holes 4:1/8 drill bit is a great conductor. Needless to say the drill bit hit the under floor battery cable and shorted into the floor covered with body deadener and all hell broke loose. Later I smile recounting this bit. The drill bit arced and caught the body deadener on fire. The the drill bit snapped as I jerked the drill sideways with some fright. I proceeded to slap my hand up and down on the flames that were trying to spread and impaled my hand on the now broken drill bit. I then yank it off to have my holed and tared hand catch on fire. My father tells me the yells of pleasure coming from my mouth were rather femanine for a bloke. Anyway he came running and picked up a bucket of sand and threw it on the floor to cover the tar and grabbed my hand and stuck it in the sand pile. The flames out and dad disconnected the battery, my hand bleeding with 2 puncture holes (the first slap must not have registered), tarred and sanded. It took a long time to clean up that mess using the left hand. Another memory hook "keep bucket of sand closer" hehe That day I learnt to run through a process in my head before winging it. It's the best was to see the near death experience happen without getting hurt.
The gear linkage on top of the gearbox had come loose again. Oh well I say, not bad for a 62 vintage. Out with the welder to make it stick proper like! Well the flames from the grease igniting got to my elbow before the now "close to hand" bucket o sand was deployed by a mate. I remember saying, "if you see flames then chuck the bucket of sand on them". Of course he wasn't looking because the welder was to bright for unshielded eyes. So the time delay allowed said feminine screams to escape and bucket of sand to hit my head before falling down onto the hot zone. Later on I asked why he threw the sand on me and he said I looked worse then the flames!
I see myself as a teacher! so other people can learn from my mistakes.
 Post subject: Re: oh the pain
PostPosted: Sat Aug 11, 2012 10:39 pm
:mrgreen: lol
- '74 Clubman Ute project
PostPosted: Mon Aug 13, 2012 2:58 pm
I made the mistake of driving my car yesterday. Valve stem on the front right threw up a protest. Ok, got a spare. Jack won't fit in the jack whole due to a) rust b) poor attempt to fix rust, which made the hole too smal for the jack to now fit into.
You would be surprised how many people at a service station don't know they have a scissor jack in their car......
I'm leaning towards not fitting my newly acquired parts to this car given its current condition.
PostPosted: Mon Aug 13, 2012 4:15 pm
Want to buy a nice blue 850 shell JC :wink: or, how about a deluxe shell in need of paint? Maybe Kuzzy's 1/2 cage shell is an option too? For more work but less $ there is a body shell in Slack's Creek on eBay.
M
PostPosted: Mon Aug 13, 2012 7:56 pm
Ive got the all clear for a shed Mark.....
PostPosted: Wed Aug 15, 2012 7:38 pm
The Alternator :D
PostPosted: Wed Aug 15, 2012 9:45 pm
my windscreen!
was parked with the nose pointing downhill, I flipped the passenger seat forward to put something in the back - it came forward with a "bang" - laminated screen now rooted
