It is currently Sun Aug 24, 2025 12:00 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 348, 349, 350, 351, 352, 353, 354 ... 568  Next
PostPosted: Sat Aug 11, 2012 5:32 pm
Did the final bits on the engine install. Surprised myself in that it fired up after a tiny bit of encouragement. Went for a drive and (thanks to the wizardry of Matt the mini man) admired my WORKING SPEEDO!! happy days.
PostPosted: Sat Aug 11, 2012 6:07 pm
For now...
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sat Aug 11, 2012 8:13 pm
After installing new front seat/safety belts, I did a final walk around to make sure nothing will fail the up-coming Road Worthy Certificate Inspection before club registration........what do I find but a weeping rear brake cylinder. Anyway, it's now fixed with new seals (on both rear wheels) so all that I now have to do is book the car in for it's inspection. That will be next Friday.
Wish me luck :)
Rod Image
PostPosted: Sat Aug 11, 2012 9:24 pm
Think positive Danny
PostPosted: Sat Aug 11, 2012 9:35 pm
I dropped the engine into the moke! A lot of things to re install but it's
progress.
M
PostPosted: Sat Aug 11, 2012 10:00 pm
with having a completly bare shell tpo start with i hung one door for the first time today had to celebrate with half a dozen cans :lol:
PostPosted: Sun Aug 12, 2012 5:35 pm
Painted my re-pinned hinges today.
Next time I'm going to get new alloy ones. The whole re-pin and paint thing is a pain in the @rsE..
Alec
PostPosted: Sun Aug 12, 2012 5:51 pm
Yesterday I drove it to mini king.
Today I changed the bushes is the remote shifter. Makes driving it much more pleasant.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Aug 12, 2012 6:22 pm
Put on the new wheels and tyres..mmmm bling
PostPosted: Sun Aug 12, 2012 6:50 pm
hubs, bearings, ball joints, I hate grease, LH just the right side to go.
PostPosted: Sun Aug 12, 2012 11:08 pm
Reamed out some trailing arms, is there any reason not to refit the original steel guide tubes as opposed to the plastic ones that are supplied?
PostPosted: Mon Aug 13, 2012 8:27 am
If you've still got the steel tubes, keep em. The plastic ones are rubbish, more so now they come from guess where.
PostPosted: Tue Aug 14, 2012 11:58 pm
Since the re-bushing how to is locked I may as well ask here,
Does the entire arm need to packed with grease or just enough to lube both ends of the shaft.
I noticed the hand brake quadrant bolt is through into the hollow part of the arm, Is this to grease the handbrake quadrant when packed full of grease or just how its cast?
PostPosted: Wed Aug 15, 2012 7:57 am
The grease nipple lubes both the outer bush and the inner needle bearing.
But if the plastic tube is broken or missing, the whole hollow arm will fill with grease. This greasing was not a design feature, the steel tubes prevented this. But it happens with the plastic tubes in the cheapo aftermarket replacement kits, because they are rubbish.
Nope the handbrake quadrant is not lubed from inside. They are bushed, if they jam up you need to clean and lube externally.
PostPosted: Wed Aug 15, 2012 12:11 pm
Thanks :D
