It is currently Wed Jul 23, 2025 6:32 pm
 Post subject: flat spot
PostPosted: Fri Apr 29, 2005 6:50 pm
just a general question. how do u tune out flat spots, by that i mean, what thing on the carby do u tune, mine has a biiiiiiiig flat spot, so yer, hope someone knows, im guessing they would :?
sean
Potato
PostPosted: Fri Apr 29, 2005 7:09 pm
the cars dead mate, if theres a flat spot means its on its last legs and going to blow up, crap start saving for new engine, maybe pack one in your bag when you go to UK (lol),
PostPosted: Fri Apr 29, 2005 7:13 pm
hmmmm, na im not that stupid, i may be 14, but i aint that dumb
Potato
PostPosted: Fri Apr 29, 2005 7:25 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Fri Apr 29, 2005 8:53 pm
meeni,
i also have sorta a flat spot, kinda cause i run a 310 scatter cam, so it does not pick up till around 4500 rpm.... but i just get round that by high idle and lots of revs :D
when u changed your exhaust, did you change the air filter aswell? have a fiddle with your needle. take it out, place it on a flat surface and give it a light file.... (up the top near the plastic black bit) might help. check your timing, points plugs etc...
let me know!
PostPosted: Fri Apr 29, 2005 9:15 pm
ok will do :wink:
Potato
PostPosted: Fri Apr 29, 2005 10:37 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
what needle you have in it atm
makka
PostPosted: Sat Apr 30, 2005 2:51 am
Forget the file.... use a hacksaw. :roll:
PostPosted: Sat Apr 30, 2005 10:10 am
i dunno what the needle size is to be quite honest!??? :?
Potato
PostPosted: Sat Apr 30, 2005 10:53 am
It could be the result of the timing/dwell not liking that bit. But generally it is the amount of fuel getting to the engine. Don't use a file. Use sandpaper. And, do you know where on the needle to use it ? Of course not. Neither does anyone else until you find the spot that's causing the problem. Yes you can find that spot if you know how. Or unless you're really liucky or spend money with Kev or Steve or Matt, etc. Could I find it ? Yes. But it would take me a week. I don't do it for a living so I'm dumb. (Nah, make that slow) First off try cleaning all the oil out of the cash pot and use ATF or 3 in 1. Them leyts talk.
smithy who knows very little
PostPosted: Sat Apr 30, 2005 11:29 am
It could be the result of the timing/dwell not liking that bit. But generally it is the amount of fuel getting to the engine at that particular time. Unless you know how please do not use a file. Use a fine grade of sandpaper. Do you know exactly where on the 16 measuring points on
an SU needle to use that sandpaper ? From here I don't. Neither does anyone else until you find the spot that's causing the problem. Yes you can find that spot if you know how. Or unless you're really lucky or spend money with Kev or Steve or Matt, etc. Could I find it ? Yes. But it would take me a week. I don't do it for a living so I'm dumb. (Nah, make that slow) First off all try clraining all the oil out of the dashot and use ATF or 3 in 1. Then let's talk.
smithy who knows very little but doesn't stop him trying to hrlp.
Users browsing this forum: watsupskip and 105 guests
