It is currently Fri Jul 18, 2025 12:52 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Aug 22, 2012 2:11 pm
What are the Mk2 ones going for now?
I paid $50 years ago.
My mate Laingy needs one to go in his Clubby hydrovan...
PostPosted: Wed Aug 22, 2012 2:17 pm
michaelb wrote:
I modified a MK2 dash for my Cooper S. Just took a few hours of carefully cutting and comparing with the old one to make it fit. Probably not concourse but you need to look carefully to note the difference. And its thicker and has no cracks. My old one ended up in many pieces. I have also had to replace the cream inner plastic surround because it had cracked and broken.
How did you fill the indicator holes :?:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Aug 22, 2012 2:43 pm
and the vertical lines ?
PostPosted: Wed Aug 22, 2012 2:50 pm
Well, as long as the grain is similar, no one will notice, unless you remove it, and play with it....
PostPosted: Wed Aug 22, 2012 3:29 pm
Steve, the English MK2 doesn't have indicator holes. ;)
PostPosted: Wed Aug 22, 2012 3:36 pm
does have the vertical lines though :(
PostPosted: Wed Aug 22, 2012 3:38 pm
angle grinder
I will notice Brett,
1962 Mini Speed sports sedan
PostPosted: Wed Aug 22, 2012 3:47 pm
You better not be judging then :lol: :lol:
Even replaced the braided pipes with black fuel hose to be correct..
It will be a long way off your car Greg, but its a work in progress....
Slowly getting there...
PostPosted: Wed Aug 22, 2012 5:32 pm
I will bring one up to Kings on Sunday (if I remember)
PostPosted: Wed Aug 22, 2012 5:55 pm
I have two binnacles - gee I was about to put one up as a swap for a set of disk brakes - sigh !!!! Feel deflated now.
Mike
PostPosted: Wed Aug 22, 2012 6:48 pm
"What are the Mk2 ones going for now?
I paid $50 years ago..."
$60 - according to 7s website. Although, both are missing the chrome surround. Interesting they don't list it as a "associated" item....
As a "by the way" I would suggest 7 are a pretty reliable bunch - I've been getting stuff off them since the 80s. Perhaps not quite as "commercial" as other US suppliers...
Cheers, Ian
PostPosted: Wed Aug 22, 2012 7:15 pm
I got my plastic dash from Karcraft about 2 years ago and it doesn't have indicator holes? Not sure why? And the vertical lines dont show too much from the front and yes I used an angle grinder at the back. If you had been at Eastern Creek on Sunday then you could have checked it out 8)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Aug 22, 2012 7:32 pm
Kc's supply would be from UK.
PostPosted: Mon Sep 03, 2012 3:55 pm
I received it today... Perfect. Even the same thickness and grain ... :D
