It is currently Tue Jul 22, 2025 1:49 am
 Post subject: Rim sizes
PostPosted: Thu Aug 23, 2012 6:49 am
Hi everyone
Does anyone know the maximum width 13" rim you can comfortably put on a round nose mini without having to cut the guards?
I like the 13 x 7 but I am concerned about having to cut the guard, I'd rather leave the guards alone if possible.
Any advice/suggestion would be appreciated.
PostPosted: Thu Aug 23, 2012 8:33 am
All depends on offset, I have 13 x 5.5s on my car, 13 x 6s have been done before as well, but both are a real squeeze.
13 x 7s are no hope.
 Post subject: Re: Rim sizes
PostPosted: Thu Aug 23, 2012 10:21 am
13" rim and comfortable shouldn't be used in the same sentence...
PostPosted: Thu Aug 23, 2012 10:45 am
Thats right, they'll nearly always rub to a certain extent, and the ride is quite harsh.
 Post subject: Mini rims
PostPosted: Thu Aug 23, 2012 7:01 pm
Thanks guys, I need 13" for the brake mod I'm doing, so no escape there, but I want the car to have some "stance" and therefore am looking for the widest rim without having to cut the guards.
In the mod, I can accomodate any offset on any wheel, so it doesn-t rub internally, the challenge is knowing how far I can push the outside of the rim before it rubs on the guards
So i guess my question should really be... Does anyone have an idea how far a 13" rim can stick out before it rubs when turning (eg 1", 1/2" etc)?.
How do tne 13x 5.5 look? Do u have any pictures?
Tnank u again
PostPosted: Thu Aug 23, 2012 8:57 pm
The wheels can stick out from the body about 1.5 inches from the lip (2 inches from the panel). That is a maximum, for 175 wide tyres.
Things that can effect guard rub:
Rim width
Tyre width
Offset of wheels
Offset of brakes
Front castor
Attachment method of arches
Ride height
What is the width of your brakes compared to standard mini disc brakes (stepped drums)?
You can get an idea for how wide you can go by using other wheels with washers behind the studs or turning wheels backwards. Obviously, this is a driveway activity only.
PostPosted: Fri Aug 24, 2012 8:09 am
Thanks Harley
Sure i agree, all clear on what items impact the rubbing and along the way each of these issues will impact how far the rim sticks out beyond the guard this was (I guess) the measurement I was looking for.
So from your experience i can go to a max of 2" from the panel with 175 tyres before i will need to cut the guard? (as stated i want to avoid cutting the guard)
Thanks mate
 Post subject: Sorry forgot
PostPosted: Fri Aug 24, 2012 8:15 am
Harkey, forgot to mention, you said you had 5.5" on yours, and i asssume you didn't have to cut the guards.
Do you have any photos you wouldn't mind posting showing how they look? If they stick out enough to give it a nice look I am happy to go 5.5"
PostPosted: Fri Aug 24, 2012 8:28 am
i ran 13 x 7 deep dish on rears with narrow drums and 13x6 on front with dicsc, had to trim 20 from the front of the arch up 150mm , 175 s all round rubber
i have 2 x 13 x 7 deep dish rims only for sale brand new
PostPosted: Fri Aug 24, 2012 8:30 am
 Post subject: The rims
PostPosted: Fri Aug 24, 2012 9:13 am
Thanks dodge, nice pics
So even with 13x6 you had to cut 20mm off the front guard (if I understand correctly for about 150 mm high)?
You photo doesn't show the front wheeles but how did you manage the symmetry of the arch? Is it obvious that the arch is now a little oblong (I guess$) or is it not noticeable?
That is my concern regarding having to cut the arch....
PostPosted: Fri Aug 24, 2012 9:24 am
Pics of my car here:
http://www.ausmini.com/forums/viewtopic.php?t=27017&start=81
5.5 or 6" wheels will give the same result, as the tyre is the widest part of both.
My car has no cut gurads, but they do rub on full lock hard cornering.
I have seen one or two cars before that had 13 x 6 superlites on them that looked like the guards were stock, but can't verify it at all.
You might be able to push the envelope on the 2" from the guard, but ride height will have to go up and the car will look odd.
If you're bored, here's a short list of cars or owners to search on the forum for as I'm sure they had 13" wheels:
Peanut- silver 850
Realxbass- silver 1275 LS
The member that put a 4efe into a pale / saxon? green 850. Can't remember the owner but the car looked stock except for the wheels.
PostPosted: Fri Aug 24, 2012 9:36 am
I have 10x 6's and have trimmed a bit so I can't see 13's being easy.. You could probably get away with some but sometimes to run a nice ride height etc it's got to be done.. Or just put up with it if it's only a slight rub as you aren't using full lock all day
PostPosted: Fri Aug 24, 2012 9:59 pm
Location: MinisintheGong [Somewhere on the South Coast]
Hey you saying no escape and implying you are committed. No way! turn back and dont go there. This is a place where 10" is better than 13" anyday. My 7-1/2" discs are all i ever could hope for so for mine the larger ones are a bit of overkill. But of course - that is a a driving choice.
And visual aesthetic - its a matter of opinion but for mine nothing beats fat 10" dia rims! :wink:
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
Users browsing this forum: No registered users and 118 guests
