It is currently Sat Jul 19, 2025 10:51 am
PostPosted: Mon Sep 03, 2012 2:05 pm
Hello All, Any tips on stopping the spare from bouncing around in the boot?
TSB
PostPosted: Mon Sep 03, 2012 2:10 pm
Early cars had a screw down clamp, later cars (around post 67?) had nothing. The boot mat helps!
PostPosted: Mon Sep 03, 2012 3:01 pm
I have nothing holding mine down without any bouncing around.
Maybe you are hitting the bumps too fast :wink:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Sep 03, 2012 4:19 pm
secure it in your garage.... increases power to weight ratio
:P
PostPosted: Mon Sep 03, 2012 5:06 pm
Fit a 35L fuel tank, it sits more snugly over the tyre. A boot board helps too :wink:
PostPosted: Mon Sep 03, 2012 5:27 pm
TSB
Bahahaha hahahaha hahahaha
Oh he was serious?! :oops:
Lillee - 1969 Morris Mini K
PostPosted: Mon Sep 03, 2012 5:52 pm
Plywood boot board + toolbox + water bottle + oddments cube..
It all goes up and down together on a good bump! But it's hydro, so not as bad as it could be. :wink:
PostPosted: Mon Sep 03, 2012 6:00 pm
If it really bothers you, you can buy the early screw clamp and base new. All you need to do is spot weld the base plate to the boot floor (not recommended if you have a rare model,), you could use blind rivets too....it just sounds a bit nasty!
:wink:
PostPosted: Mon Sep 03, 2012 6:14 pm
The Mini King
If You have Twin tanks I would Fit the Cooper S boot board, If only one tank (not 7.5 gallon ) then I would fit the Cooper Boot board,
PostPosted: Mon Sep 03, 2012 6:35 pm
:P
but ruins that perfect weight distribution :p
PostPosted: Mon Sep 03, 2012 8:56 pm
TSB
do you actually have issues with it bouncing around?
PostPosted: Tue Sep 04, 2012 12:07 am
http://www.google.com.au/imgres?q=mini+ ... s:24,i:230
PostPosted: Tue Sep 04, 2012 4:20 am
To stop this happening all you will need to do it put a piece of form ply size of the wheel rim at least on top of the wheel than a Besser Block on top then get a piece of timber about 4 X 2 and a foot long or so and Jam a Scissors Jack on top of the Brick and the piece of timber jammed under the parcel shelf and wind the Jack up. This should also automatically lower the back end of the car too as a bonus and spare wheel will not bounce around. LoL
"Let us remove your "SHORTS"
PostPosted: Tue Sep 04, 2012 9:49 am
I have the usual spare, battery cover and boot liner, and I have never had the spare move anywhere, even with some fairly vigorous country driving.
PostPosted: Tue Sep 04, 2012 9:56 am
AEG163job wrote:
http://www.google.com.au/imgres?q=mini+rally+cars&hl=en&client=safari&sa=X&rls=en&biw=1438&bih=752&tbm=isch&prmd=imvns&tbnid=Ko8Fodoso7VXtM:&imgrefurl=http://autos.ca.msn.com/motorsports/gallery.aspx%3Fcp-documentid%3D21884660%26page%3D2&imgurl=http://blu.stb.s-msn.com/i/C7/83956D1C0D6C51118F914AF1E5BDE.jpg&w=500&h=300&ei=RrlEUP75BemeiAeS-oGoDQ&zoom=1&iact=hc&vpx=165&vpy=418&dur=2988&hovh=174&hovw=290&tx=119&ty=92&sig=113299875793647814699&page=2&tbnh=107&tbnw=179&start=24&ndsp=31&ved=1t:429,r:25,s:24,i:230
I think this is what you wanted... ;)
Users browsing this forum: awdmoke and 91 guests
