It is currently Fri Aug 08, 2025 9:37 pm
PostPosted: Sun Sep 16, 2012 7:38 pm
Wold anyone be able to provide me with a picture of the placement of their child restraint anchor/anchor points on the rear parcel shelf. I have the document from vic roads for fitting them but the only place I can fit them due to speaker whole cut-outs and the legal distance of 50mm from punched out or perforated metal from these in the parcel shelf will put them very near the top edge of the rear seat is this ok?
Thank you
zeroasylum
PostPosted: Sun Sep 16, 2012 8:12 pm
I don't think you can have belt or child seat anchor points in a parcel shelf with speaker holes at all. :?
PostPosted: Sun Sep 16, 2012 8:17 pm
Why not? Leyland did.
PostPosted: Sun Sep 16, 2012 8:19 pm
Hi Guys thanks for the replies. According to this document you can just needs to be 50mm from the cut-out
http://www.vicroads.vic.gov.au/NR/rdonl ... /VSI17.pdf
Thanks
Zeroasylum
PostPosted: Sun Sep 16, 2012 8:37 pm
This is how Leyland did it in the 70's.
The red circle marks the child restraint hole. The green circle marks the seat rear seat belt hole (for the opposite side belt)
The speaker hole has not affected the structure under the shelf that the belts mount to.
The earlier cars have a totally different shelf structure (well just a tin shelf and very little structure!)
PostPosted: Sun Sep 16, 2012 8:41 pm
My parcel shelf already has that hole cut in it 1990 car also has the hole directly opposite it which was the one I was thinking of but if the other is what is used guess that's ok unless someone else has them in another place
Thanks
Zeroasylum
PostPosted: Sun Sep 16, 2012 8:45 pm
All UK cars and earlier Australian cars are different to the one in my photo.
PostPosted: Sun Sep 16, 2012 8:53 pm
Ah I see Mine pretty much looks like this one. Link to site that sells the repair panel but mine has all the smaller holes in it like this one don't have a photo of mine right now. Any advice on which hole to maybe use.
http://www.minispares.com/product/Class ... o%20search
