It is currently Sun Aug 17, 2025 9:19 pm
 Post subject: What are these numbers
PostPosted: Fri Sep 28, 2012 7:17 pm
Whilst fitting the water pump to my recently rebuilt 65 Deluxe 998cc motor, I noticed these numbers (YY8228) stamped into the block. Any ideas?
1964 998 Cooper , 1968 Morris 1100
PostPosted: Fri Sep 28, 2012 7:34 pm
What area of the block is that?
PostPosted: Fri Sep 28, 2012 8:35 pm
The Mini King
Have a look at Your Main bearing caps they should have the same numbers
stamped on each cap
PostPosted: Sat Sep 29, 2012 8:44 am
Thanks John, wish I could but the motor is now assembled, minus the head, and ready to go back in. I've had this motor for over forty years and it is the first time I have ever seen those numbers stamped near the water pump. I have now learnt something new about our venerable little cars.
PostPosted: Sat Sep 29, 2012 9:23 am
The Mini King
Thank You, It is a handy thing to know
PostPosted: Sat Sep 29, 2012 10:24 am
Do they all have this? Why would you need to know the bearing cap number from the outside?
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sat Sep 29, 2012 10:58 am
Mains caps are not interchangeable from block to block once machined, so they had to stamp it on the block somewhere.
BMC/BL just chose to stamp it on the front of block, up the top RH corner.
Other cars are usually stamped on the bottom flange...
PostPosted: Sat Sep 29, 2012 11:16 am
The Mini King
Yes Every Mini Block I have ever checked Has a number stamped there
They are stamped there so that when an engine is being put together, You can check
that the correct caps are fitted. to the correct block
The reason they are stamped there is it is a nice flat area, so stamp is clear, and not in a position to be de faced often
PostPosted: Sat Sep 29, 2012 8:02 pm
Interestingly, I have seen one Cooper S block with the Main cap number stamped on the pad where the fuel pump would mount,
Was puzzled when I couldn't find it in the normal place,above and to the right of the water pump, so went looking for it....
Dave
 Post subject: caps not with block
PostPosted: Sat Sep 29, 2012 9:00 pm
so if caps are not with block , what are the options please, cheers
PostPosted: Sat Sep 29, 2012 9:12 pm
Paperweight
Doorstop
Anvil
 Post subject: doorstop
PostPosted: Sat Sep 29, 2012 9:35 pm
thanks
PostPosted: Sat Sep 29, 2012 9:46 pm
Seriously, the block is pretty much useless with the wrong caps. You can get it machined for a lot of money but then you will run into problems with the timing chain.
Try to get the matching caps for that block or get another block with caps.
 Post subject: main caps
PostPosted: Sun Sep 30, 2012 8:31 am
Luckily i haven't bought a block without caps). My non mechanical mind was trying to reconcile the availability of high end replacement main caps such as http://www.swiftune.com/Product/1000/swiftune-steel-main-cap-set-1300-mini-4-bolt-centre.aspx , given the block and caps are matched.
Again , I don't have any experience or knowledge in engine rebuilds, but i guess throwing big money at something can offer partial solutions. Cheers
 Post subject: Re: main caps
PostPosted: Sun Sep 30, 2012 4:26 pm
It certainly is an option and it can be done. It is not cheap though.
Users browsing this forum: No registered users and 272 guests
