It is currently Sun Aug 17, 2025 1:56 pm
PostPosted: Sat Sep 29, 2012 9:42 pm
anyone else heard the rumours if your cars been out of rego for a long period it's no longer going to be a walk in rego?
I hear murmurs they're going to have to go through regency if they've been unregistered for long periods. what i hear is if it's out of reg for something like 2 or 3 years it'll have to go over the pits
anyone know anything of this?
all i've got are rumours
PostPosted: Sat Sep 29, 2012 10:04 pm
I don't know about rumors, but when I called about my mini I was advised it had to go over the pits. Mind you there is no record of it ever being registered in Aus :shock:
PostPosted: Sun Sep 30, 2012 12:54 pm
This doesn't sound like a bad idea.
Sure it's a hassle, you might actually have to fix your high beams and indicators but it will get a lot of scary cars off the road
Rather, prevent them from getting back there in the first place
You're so square
Baby I don't care
PostPosted: Sun Sep 30, 2012 10:21 pm
Scary for all of us with modified cars that the rogo has lapsed on.
PostPosted: Sun Sep 30, 2012 10:27 pm
I guess you would only be concerned if your vehicle was not roadworthy? if it was then a trip over the pits should not be a worry.
PostPosted: Mon Oct 01, 2012 1:25 am
I suspect it needs to go to regency for an ID inspection...
I'm not sure it needs a roadworthy..
PostPosted: Mon Oct 01, 2012 6:53 am
The ACT has 2 year's unreg before having to recheck for rego.
It works well and we only have to put 3 month rego on to reset the time frame.
Only scary if you have illegal mods. It's really just a safety check.
I personally would rather think that the car behind me actually had brakes etc..
Cheers Rob
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Mon Oct 01, 2012 4:38 pm
If the car was previously registered in SA, many people have re-registered cars that were years out of date by doing everything online.
True story......
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Mon Oct 01, 2012 4:50 pm
Whilst it would be great to be able to do that with a classic, I can just imagine the death traps and illegally modded cars just slipping through :evil:
Personally I think it is much better to put them over the pits.
PostPosted: Mon Oct 01, 2012 5:56 pm
Why are people so worried by safety inspections? I'd prefer to know that I, as well as other road users, were driving safe cars.
Working as a mechanic for 17 years I saw all sorts of death traps, and the fewer of them on the roads the better.
Dicko.
PostPosted: Mon Oct 01, 2012 6:28 pm
opening up the 'can of worms'...
I see a big difference between safety and legality...
my seat mounts made by a very experienced trade qualified boilermaker, i would rate at being much stronger than the original mounting style, however as i haven't paid the 3k to get them engineered, technically they're illegal.
also a thing as simple as a sports steering wheel is not legal, though i'm sure most of us have one on a car...
sure i can change a heap of parts out to get it over the pits but what a PITA.
I like SA's slack systems! rust buckets just make us more wary drivers!
end of can opening - debate-bag me away!
:P
PostPosted: Mon Oct 01, 2012 8:10 pm
woodwormm wrote:
...rust buckets just make us more wary drivers!
:shock:
PostPosted: Mon Oct 01, 2012 8:52 pm
It sounds a lot better when you use the Department's terminology.
"The onus is on you to ensure the vehicle is in a roadworthy state."
If you try otherwise it can be dangerous and/or expensive.
But everyone is used to this being the situation for other ideas, like speeding, mobile phone use, pedophilia or failing to indicate.
The nation would be up in arms if vehicles were required to be fitted with a mechanical speed limiter or a government approved speed checker that reminds you that you're over the speed limit.
(if you don't already have a wife)
What would you like? A sense of responsibility or a nanny state?
PostPosted: Wed Oct 03, 2012 6:57 pm
Wonder how fibreglass panels, bonnet pins, perspex windows, roll cages, beam axles will fare? This one was last reigistered [by me] in 1982 and has been sitting at the back of my shed since then. I still have the original [1967] plates.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Oct 04, 2012 7:02 am
Tomboss Breweros
Registered owner can re register whenever, i got a mini going that had been off the road 18 years, the owner took the last paper into an office paid and got a sticker, easy.
kimini wrote:
Jimmyinamini wrote:
Users browsing this forum: No registered users and 317 guests
