It is currently Tue Aug 05, 2025 6:36 pm
 Post subject: Crack? in brake part.
PostPosted: Sun Oct 07, 2012 2:05 pm
I felt some wobble on the last drive and have found this
What has cracked there?
PostPosted: Sun Oct 07, 2012 2:08 pm
Nothing. The split washer is designed that way.
PostPosted: Sun Oct 07, 2012 2:10 pm
Oh good..
I hoped it was. But the edges looked a bit rough.. probably just grit.
Hub nut was a but loose. Will just try tightening it up a bit.
PostPosted: Sun Oct 07, 2012 2:46 pm
Online
Is that Kiwi speak :?: :lol:
PostPosted: Sun Oct 07, 2012 3:40 pm
Do Kiwi's have loose butts?
PostPosted: Sun Oct 07, 2012 7:38 pm
Ah shut.
PostPosted: Sun Oct 07, 2012 8:50 pm
The Mini King
Oh good..
I could be Wrong, But I would check Your drive flange where it sits up against the Bearing I think it may be worn Also in the photo the split washer looks like it may be sitting to far into the drive flange,
PostPosted: Tue Oct 09, 2012 12:40 am
The drive flange being......
I suspect there's some wear in there..er.. somewhere..
PostPosted: Tue Oct 09, 2012 8:06 am
If the nut goes loose (with the split pin still in place) there's a good chance your wheel bearings are about to die. Tightening it up will only kill them faster.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Oct 09, 2012 8:15 am
If it's been run long with the CV nut loose (which it looks like) both the drive flange (the thing that washer sits in) and the CV splines may be knackered. Along with the bearings...
I'd pull the drive flange + rotor off, and look at the inner face of the drive flange. If it's grooved where it sits against the bearing you need a new drive flange. And if the splines are bad on the CV where it sits, replace that too.
BTW that tapered washer has had it... and probably the nut face is worn.
Whilst it's all out you might as well replace the bearings and seals, making a proper job of it. :wink:
PostPosted: Tue Oct 09, 2012 2:38 pm
The Mini King
The drive flange is The part that is bolted to the disc Rota it has splines inside where The CV fitts And the inner face sits up Against The bearing, As I said before I think You will find That this surface will have grooves worn in it which will upset the pre load on Your bearings.
If You take the caliper off You should be able to remove disc and drive flange together
check internal splines check wear on drive flange, als check splines on CV joint,
As I mentioned before I also think the split washer is worn. and
For the cost of wheel bearings these days I would replace them aswell if the drive flange shows wear
PostPosted: Mon Oct 15, 2012 9:47 pm
Ah ha...
http://minisport.com.au/prod406.htm
Now I have seen it, I understand..
I'll pop mine off and take a look.
What about the safety angle? OK/NOK to drive for a short period?
And when did swivel hubs stop being a million dollars each? China?
PostPosted: Mon Oct 15, 2012 11:07 pm
Here's how it looks.
The washer. A bit of a ridge.
The outer of the flange, - doesn't seem too bad.
The inner. A bit of wear down there..
PostPosted: Tue Oct 16, 2012 7:09 am
The Mini King
Ok, Needs Drive flange, split washer, and as I said before I would also replace the wheel bearings, also check the splines on the CV joint
PostPosted: Tue Oct 16, 2012 7:56 am
Cheers John.
You're, like, the Prince Regent of minis. :)
Another picture coming.
Users browsing this forum: No registered users and 116 guests
