It is currently Tue Aug 19, 2025 6:18 am
PostPosted: Wed Oct 10, 2012 5:18 pm
Hello people. Need some ideas on why my car is so hard to start when cold. I would guess it needs about twenty to thirty cranks, with full choke, before it even tries to fire. When it does eventually fire it runs like a dog's breakfast, almost as if it is flooded. Once it clears itself and gets warmed up it is fine. Starting from warm is no drama. First kick every time. I have tried starting with no choke at all, half choke but no luck at all. The motor has twin 1/1/2 SU's and electronic ignition from a Honda Civic, I believe. Any ideas please? Thanks
PS I would have the car dynotuned to get to the bottom of this annoying problem but none around where I live.
PostPosted: Wed Oct 10, 2012 5:39 pm
Have a look at the choke and see if it is adjusted and working.
Also, have you checked the condition of the spark plugs?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Wed Oct 10, 2012 6:33 pm
Thanks for that. I will check the chokes tomorrow. The car is currently fitted with Split Fire plugs SF6B if that makes any sense to you. I thought plugs may be the problem. What are the correct ones for a 70 Mk2 S. Thanks
PostPosted: Wed Oct 10, 2012 7:57 pm
I would try a new set of plug leads... had the same problem a while ago and that solved it... and its a cheap trouble shoot.
Cheers, Ian
PostPosted: Wed Oct 10, 2012 8:08 pm
+1 on the choke.
Get someone to slowly pull out the choke while you watch.
There should be 2 stages as the choke is pulled out.
1 a cam should slightly up the idle
2 another cam should cause the jet base at the bottom of the carb to drop down.
I've been told if they are grumpy on cold start/drive that's a good sign they are set right (not too rich). But it shouldn't be that hard to start. I bet the chokes not operating)
Users browsing this forum: Majestic-12 [Bot] and 91 guests
