It is currently Wed Aug 13, 2025 3:21 am
PostPosted: Fri Oct 12, 2012 8:19 pm
Just wondering did you get the 4 syncro box magic wand boxes in OZ.
I am looking for a case.
Ta
Kiwiinwgtn
PostPosted: Fri Oct 12, 2012 8:31 pm
Back in the seventies my ex had a poverty pack mini 1100 (ex county council) and although I cant clearly remember I am sure it had a full synchro box. It certainly had a magic wand.
Mike
PostPosted: Fri Oct 12, 2012 8:34 pm
The four synchro remote gearbox was used with what they called a direct change (i.e. without the remote extension) in some of the poverty pack sedans and the vans and Mokes in the late '60s through to whenever the rod change boxes were phased in.
Its usually called a pudding stirrer, as opposed to a magic wand.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Oct 12, 2012 8:42 pm
Looking for a magic wand 4 syncro (pudding stirrer) not remote type.
I will post a pic tomorrow
Ta
Kiwiinwgtn
PostPosted: Fri Oct 12, 2012 8:45 pm
I thought they were all 3 synchro.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Fri Oct 12, 2012 8:48 pm
This is what we had for the 4 syncro...
PostPosted: Fri Oct 12, 2012 9:07 pm
That is the "puddin' stirrer" shift. Used in POV packs, Mokes too.
3 synchro ones before that were magic wand (had 850 style diff housing).
PostPosted: Fri Oct 12, 2012 10:39 pm
Back in the 60's my original Mini as with all 850s had a 3 synchro Magic Wand change - I got my Army Truck license learning on 6X6 Studebakers that had no synchro on any gear. After that it didn't matter that the Mini didn't have synchro on 1st :wink: :roll: :lol:
David L
PostPosted: Sat Oct 13, 2012 7:49 am
I have one in my van, direct change.
PostPosted: Sat Oct 13, 2012 8:05 am
I've never tried it but I believe that the direct change remote boxes will fit perfectly into the same spot as an 850 magic wand box, without having to modify the hole in the floor. From the outside you wouldn't know the difference.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Sat Oct 13, 2012 8:23 am
Although the diff housings were line bored on assembly and are theoretically not interchangeable, you can retrofit an 850 diff housing to a 4 synchro remote box.
Provided that you check the bearing bores accurately for roundness and size when bolted up.
This may entail removal of the 2 dowels, and/or machining of the diff housing flange.
Back in the `60s it was popular to do the opposite (fit a remote diff housing onto an 850 box)- the same rules apply.
PostPosted: Sat Oct 13, 2012 9:20 am
my 73 van has the magic wand 4 speed box came as standard
65 panel van Sprog
73 panel van Iggy
PostPosted: Sat Oct 13, 2012 7:45 pm
does it have this plate to hold the gear stick in..
PostPosted: Sat Oct 13, 2012 7:58 pm
Looks like John from guess works has already got it sorted
http://www.guess-works.com/Shop/Gearbox/NewProduct.htm
PostPosted: Sun Oct 14, 2012 5:55 pm
The Mini King
That plate is required if you are using the remote type diff housing
If you convert to the 850 style diff housing then this is not Used, if You have the motor out of the car I would consider changing to pot joints whilst you are working in this area
that is if you are not looking to keep the car original
Users browsing this forum: Bing [Bot] and 287 guests
