It is currently Sun Aug 17, 2025 7:20 pm
PostPosted: Sun Oct 21, 2012 9:09 am
Just picked up an ex tarmac 'Mini 1000 series' shell that was last CAMS log booked in 1997.
No ID plate. Car number on firewall is 236**. Radiator shroud number is 231**. Can only see the 'M2' but not the numbers underneath.
Has 3 screw tail lights and 850 sliding doors. Has been running a remote and can see where pudding stirer has been but welded (or factory) closed.
Not sure if it is an 850 or Deluxe body? Morris any ideas?
Dave K.
PostPosted: Sun Oct 21, 2012 10:39 am
Have a look at the door latches on the door opening on the body which one of these
http://www.minisport.com.au/prod1613.htm
http://www.minisport.com.au/prod627.htm
PostPosted: Sun Oct 21, 2012 2:07 pm
I think it is a Deluxe. Probably early 67. I could be wrong though!
Any signs of hydro pipes?
Does the firewall have an extra dent where the master cylinders sit on an LHD car?
PostPosted: Sun Oct 21, 2012 2:30 pm
I think you are right. Pulled the ignition switch out and has 66 number on it. Looks like holes at the rear where hydro covers were.
Dave K.
PostPosted: Sun Oct 21, 2012 2:38 pm
A 66 should be right for that car number if I am right. The other electrical items all have dates too if you can find them. Maybe the boot lock as well but on a race car this is fairly unlikely!
The firewall pressing is probably the easiest clue, along with the door latches.
PostPosted: Sun Oct 21, 2012 7:59 pm
or the front valance :idea:
Users browsing this forum: No registered users and 219 guests
