poeee wrote:
BTW the Nissan A12 has very little in common with BMC's A series... a lot that is written is BS.
They are actually more so a redesign of the Austin A40 1200cc engine (physically between the A and B series). I believe...
They are
supposedly similar, but look where the cam is (LH side), and look where the pushrods go- (in tubes between the spark plugs) it's nothing like either the old A40, or the A series....
I think people are confusing the relatively modern A12 with the motor in the old Nissan Bluebird (1st edition) of the 60s, which ain't the same animal. That one did bear a resemblance to the old A40.
Which was common back then, The Isuzu Bellett motor was based on the Hillman Minx 1600. Their head gaskets were practically interchangeable.
I can recall all this coz I wuz here then.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
